stichn56
Everything posted by stichn56
  1. does anybody know where I can get a new or rebuilt carb for an 87 sub gl wagon, front wh dr. non turbo, 1.8 L?
  2. you might be able to get the bolt by the head size. it's a 22 mm socket. if you find one, you might want to add some lock thread. small tube you can get at any auto parts store. runs about $3-5$. drip on threads prior to install. then torque to specs. hope this is helpful.
  3. these engines aren't very powerful anyway. when even a small vacuum leak can feel like a cyl's not firing.
  4. I have an 87 sub Gl wagon, non turbo, with a 1.8 l carb that needs a carburetor. anyone know where I can find one?
  5. chdeck fuse for elec pump. also, if a used pump, could be bad.
  6. i replaced both belts, checkd the timing marks, got fuel, spark, checked timing @ flywheel, ccheckd dist, still won't start. does this have an onboard pc i don't know about? please help.
  7. i need a clutch release cable for 87 sub gl/sw. where can i get it? thx
