adam87amp
Everything posted by adam87amp
I replaced the engine temp sensor 3 months ago (can't remember the exact reason). I did replace coil pack this week, due to a misfire on every cylinder. Runs somewhat better, but not as it should be. Do you think replacing the front O2 sensor will make a huge difference with out the cat being in there (even though removing the cat was a suggestion from a friend I do not believe that was a good choice, these cars need the cat to run right don't they)? I have thrown a scanner on it (keep it in the car) but I am not sure what menu to go into to see if it is in the closed loop.
replaced thermostat with oem clutch was done this past weekend due to the last one i put in being advanced auto clutch and one of the springs fell out of the clutch plate replaced with Sachs Clutch Kit exhaust pipe is free breathing since i have cleaned front o2 sensor there has been no cel for a week. i drive a total of 100 miles a day round trip to work and it is all highway i always to the mathimatical way of figuring gas mileage. I have been averginge 17 mpg between fill ups approximately 170 miles on 10 gallons of gas, i don't even get 2 full days of driving without filling up
The gear ratios were check and every thing checked ok throw out bearing clips are in good shape throw out is snug on input shaft (just not to snug) don't know the maintance on the trans before I got it but ( since then it is taken care of) a local friend recomended checking the rear diff and making sure there is plenty of gear lube :-\
I have a 97 OBW 5 spd that i picked up due to blown head gaskets All I have done Heads machined new valves/adjusted upper gasket kit water pump flywheel machined new clutch new vacuum lines new radiator new transmission new motor mounts new transmission mounts new rear struts new rims and tires new knock sensor new ect the problem I am having now is that the car runs great and shifts great for about a half hour. After it is up to temp for around a half hour like i said the clutch/whole car shudders/chatters when you are leaving a dead stop (1st gear). The rpms can be cranked up and clutch feathered, but i know that will toast the clutch. Does anyone have any suggestions? Or did i just buy a junk clutch from advanced auto parts?
