jason2o
Posts posted by jason2o
Good deal Autobone still carries the sensors. Although it had to be ordered. hopefully Ill get better mileage now too.
I have an 87' GL-10 that has been hard starting since I bought it... But with the new colder weather that has been amplified to almost a 30 sec pull on the starter. Plugs are black and new, I replaced all the ignition parts with NGK stuff as im a firm believer in NGK parts.
Im thinking its a Coolant sensor, but where is that bad boy? And if thats not it what are my other options?
Car has 120k on the ODO, and was running great even though rich up untill it got cold outside (below 40). The cold starting is a little rough but it starts. other then that there is a little oil bypass on the turbo, but not enough to worry yet.
Well the can doesnt do anything, kinda frozen. Is there a source ( to purchase) for these things? Going to try and mess withthe lever manually..
Is the engagement lever/solenoid on the center diff in the same position as the one on a d/r trans..? The air solenoids on the firewall check out ok..
Thanks!
Thanks! Thats great info..
Hey all I already had an '88 gl d/r 5mt sedan, now I lifted it and picked up an '87 gl10 5mt fulltime 4wd sedan for my DD..
The GL10 runs great but... the center diff is always locked and displays a fault on the dash, leaks oil, tach no workie, and most of the switches around the gauge cluster are gone or defunct..
Anybody have any ideas about the Diff.. I dislike barking tires in parking lots.. valve covers are leaking like a ***************...
I did some research theres not much on the fulltime 4wd diff lock up..
I just got mine as well I left the rubber block and plate alone and only had to weld a plate onto the 4wd shifter arm to augment the position.. Other wise no FWD! all is well on mine except the lh front mudflap is stuck on and i need it off to not rub!.. Took it on the trail anyhow... nary a problem! the ruts that I dreaded before are no more..
The trannies on the GTS SUCK, I went through 2 in 45k on my '00 GTS. I got accused of racing etc. , it was my commuter the problem ended up being the synchro's on the 6spd is of sintered metal construction so they would die young. The later models lasted a little longer because the Rev. limit was lower then the '00.
Thanks for letting me in, I payed by paypal. Thanks!
Im thinking im probably too late on this?
It will either be a in line clog of some kind or dirty condenser. Do you do any off-roading? I am not sure if you have an orifice tube, but that is a possibility.(orifice tubes are basically filters inside the lines) Can you find out why it's cutting out? High limit switch would be my guess.
I dont do much offroading, I live on a gravel road and sometimes just the drive to and from home can be just as harry as off-roading.. Condensor and radiator are squeaky clean, wash all the cars once a week. I wouldnt think that the high pressure switch would be kicking on at idle, it would be hard for me to believe it would be having a high enough pressure to kick off at idle but not at speed.. I was under the impression orifice tubes were a way of converting volume to pressure and vice versa..
What im trying to figure out is whats the deal with the trip sensor and reluctor ring on the compressor clutch?
Hey all Im having some stupid issues with my a/c its cycling like mad at idle and eventually shuts itself off. At 5mph on up its kick rump roast and blows ice cold.
Its a stock ea82 r12 unit running r12..
Well I have been hitting the Soobie pretty hard and I finally decided to do some maintenance, only performed an oil change prior to this weekend. Changed plugs, wires, cap, rotor, fuel filter and the EGR purge solenoid.... The plugs were eroded to almost nothing, the car is alot smoother now! Got my pugs from McBrat and ordered up some tires... things are coming along.. now going to talk to some people about a lift kit....
Well after checking out alot of different sources the best and cheapest I found was Partsgeek.com, they have new ones for $41 and some change. Hitachi brand.
Type of Wrenching: Professional A&P mechanic for over 11 years, Automotive Shadetree, Automotive, robotics and Aviation Maintenance.
What: Mustangs, Mopars, Honda (car + ATV), Harley/Buell, Kawasaki, Citation Jets, Bell Helicopters, FANUC+Custom robotics..
How long doing it: 17 Yrs.
Other skills: I have been involved in aviation, maintenance and engineering for 14 yrs. I have done everything from rebuild a briggs, hot section on a P&W 535 to design and build a automated robotic assembly line... Currently I am attending school full time and preparing for law school.
Thanks everybody!
Been a lot of help if only in the last week!
Now if only i can keep the wife from trashing the Subi! she ran over a log and completely destroyed the passenger cv! lol
Thanks, code 34... egr solenoid. off i go to find a solenoid from a random import zzz
By cel I mean check engine light, how do I get the trouble codes? I have read alot of back posts, I seem to have all the connectors but it's very unclear if the cel light blinks and which connectors should be connected on my car. I can reset the cel but that's about all I seem to get done. The cel seems to be related to running the a/c.
Thanks for any help. I'm not new to wrenching just subarus!
I have an 88 gl fuel injected. 4wd dual range , I'm trying to check the cel , how does one do this? I have all connectors of alll Years.... Ugh! Help
Dead sexy can you pm me your # I want to order a 2or4" kit
Thx, Jason
Welcome aboard, Jason. Great place here--but I think you know that already!
Loved your description . . . (everything works on it, including the CEL!)
Yeah, about that... Having a helluva time trying to figure out the CEL as it started hitting more often with the use of the A/C more then normal..
Seems I have a million connectors and cant figure out how to get codes.. lol.. Its an 88 GL with F/I.. ugh..
Hello all, I been lurking around here for a bit! Finally joined since im hard looking for an SVX that meets my criteria (quality/price) I have an 88 GL sedan w/4wd (everything works on it, including the CEL!). Its time to get something that is a lil faster and more comfy'. I have a hard time getting over 75MPH, lol.. But love the fact that I can go off road (lol my driveway) and not have to take it as easy as driving on the street in my mustang. Fun Fun Fun...
Im hoping to step up to an SVX this weekend I have 3 that are within 100 miles im looking at on saturday. Eventually Ill do an MTX swap, just not sure how tough it will be on an AWD car, ive done about 6 swaps on fords & hondas (engines, trannies etc..), never been into a Subi'.
Jason
87 Gl-10 Hard start after warmup Running Super Rich
Posted
Found the Tell Tale Sensor what a pain in the rump roast. It shattered upon removal but was totally green from the sockets up about 3 inches! Replaced it all with a new sensor and a honda F/I plug... WAY better quality, and you dont have to worry as much about losing the retaining clip as it wraps around also the Honda F/I plug I Used has gasketing inside.
Talk about the fastest, cheapest and easiest + most effective fix i've ever done to a car.
200% better!
