Major Front end shimmy under load help!
2007imp replied to mgkmark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXe
Shimmy over 60
2007imp replied to 2007imp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProblem finally fixed.Front drivers side wheel bearing bit the dust.Now drives like new.
check engine light w/ blinking cruise light
2007imp replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSame problem with my 05 legacy.Loose gas cap.
2006 IACV cleaning question
2007imp replied to jkb_6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem in my 2005 legacy, low idle, stuttering on acceleration, all i did was pull off the air intake,and used a toothbrush and a little gasoline to clean off the throttle body plate. It had lot of black soot type stuff built up around the edges. Problem solved,idles and runs perfect now.
Shimmy over 60
Just installed 4 new kybs in my 05 legacy sedan and now have a shimmy/vibration when going over 60. Could it need an alingment,It didn't have shimmy before. I made sure to mark the camber bolt and put back in orignal position.Could the new struts make the worn components be more felt ie balljoints/tierods/bushings. Thanks
New struts
Anyone know of a good place to buy 4 new struts for 2005 legacy, rockauto was like 290 and one retailer on amazon/just suspension was 210 for kybs. Also any install/removal tips for legacy. Thanks
Low idle
2007imp replied to 2007imp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the replies,this car does have the drive by wire throttle control.Has anybody had their car reflashed/updated at the dealership, if so any idea of cost. I am also looking to install new struts front and rear,I was thinking of putting in kybs,anything special i need to know,direct fit or need some sort of mount kit.I know most are custom fit for each vehicle. Thanks
Low idle
2007imp replied to 2007imp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCleaned the throttle body plate,no more issues,thanks for the help!
Low idle
2007imp replied to 2007imp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey thanks for all the good info.This morning when i started the car the idle was higher than it had been on previous starts aroung 1000-1500 rpm. No stalls or hesitation.Later this afternoon i tried again and it had the same low idle issue drove for maybe 5 min and cleared up. Put in new airfilter and new plugs,old ones didnt look bad at all,some oil in plug wells though. Next will be new plug wires.
Low idle
2007imp replied to 2007imp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen i first got the car it wouldn't run with out one foot on the brake and the other on the gas.The stall/low idle problem usually happened within the first 1/2 hour of driving, it also had a miss with the cruise on at like 70mph.Now it seems like it is alot better,some oil on plugs wires,don't know when or if ever changed.Possible arc/grounding issue? Bad gas? I filled with high octane gas and threw in some injector cleaner.
Low idle
Hey guys great site,l just picked up a 2005 legacy limited w/140k and it seems to have a problem with really low idle speed. When you come to a stop sometimes the car will die or idle really low,but after driving the car for a while the problem seems to go away. No check engine lights or any stored codes. Any ideas. Thanks
2007imp
