Everything posted by revox
erratic acceleration -- cause?
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's been weeks, and the heat has been crazy. I don't think there's any lingering water.
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXModel and year would help. Oh, sorry! I thought I had included that info. It's a 98 OBW with a 2.5 engine. Recently (last Nov) had the head gasket, water pump, timing belt, 1,000 seals and o-rings replaced. Engine runs very well and doesn't leak a drop. Have you reset the ECU by disconnecting the battery for 15 minutes? No, I haven't tried that. I'd rather not because getting my keyless entry to work was a bear! ..but I will as a last resort. Fuel filter? Nope. I haven't changed it. I should probably do that soon. How many miles on the T-Belt, if it jumped a tooth or 2 you could have timing issues. Again, it's only 9 months old. Not even 10k miles. Is this an erratic problem or constant issue? the problem is mainly within he first 15 minutes of driving. It eventually goes away, but it happens every day. You could trace all the vacuum lines and connections to make sure everything is correctly hooked up. You know, I seem to remember this problem starting after I washed my engine. I wonder if I knocked something loose. I'll poke around.
My car, which is a never-ending source of headaches for me, has a new issue! When I step on the gas, it hesitates a few times. It wants to go go go, but something is making it feel like it's missing, or hesitating. I recently changed my knock sensor (yay! the CEL is finally off!), but I'm pretty sure it was doing this before I changed the sensor. So what are my primary suspects? Vacuum leak? another sensor (o2)? Maybe something else? My car has been thru a lot since I bought it back in September '10, but it's just about all good now. This is my only problem, and I can't wait to get it resolved. any ideas?
The Money Pit has a new issue -- erratic idle!
Well, I bought this 98 OBW 2.5 in September 2010. It really seemed like a great car. Very good condition, and drives perfectly. Two weeks later I had to have the head gasket/water pump/timing belt/1,000,000 seals and o-rings done. I was driving home from work yesterday and my top radiator hose exploded, so I pulled off the road and got a tow home. Bought the new hose for $7.99 (I was shocked that a Subaru part could be so cheap) and fixed the problem. Now, the very next day, my car is idling very erratically. When I first start the car it goes way up to about 2500 rpm for what seems like an eternity (probably only 20-30 seconds), then drops to the usual 1k-ish rpms. BUT when I touch the accelerator pedal, it revs again then slowly comes back down. My CEL is on due to my knock sensor, but I think I'll have it checked again to see if there's some new issue causing my idle problem. Also, I washed my engine with Gunk yesterday because of the radiator hose explosion. Maybe something is wet? Maybe there's a vacuum problem? Any ideas?
98 OBW won't crank!
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried starting the car in neutral. No-go. Also, we used a meter to check the wire going to the starter solenoid and there was nothing while turning the key.
98 OBW won't crank!
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis this the part you're talking about? Subaru Ignition Switch
98 OBW won't crank!
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFunny you should mention that. My friend ran a wire from the starter to the inside of the car. He put a cigarette lighter plug on it. To start the car I just turn on the key then put that thing into the socket until the car turns over, then I pull it out. It's SO GHETTO! ..but it's only temporary until I can get the ignition changed.
98 OBW won't crank!
A new problem started (no pun intended) yesterday. My car just wouldn't start. No cranking, nothing. All electrical still worked when the key was on. I can hear the starter relay clicking. I tried removing the alarm's kill switch, but it still won't start. A friend pulled the cable off the starter and tested it while I turned the key, and said there's no power to the solenoid wire. Could it be my ignition switch? I'm suspecting that because it seems loose, and the courtesy beep is (and has been since I've had the car) intermittent. Is there anything else I should check before changing the ignition switch? thanks!
Shredded seat belt = Warranted!
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnormal wear & tear is NOT covered under warranty, but if they're actually defective, then yes, they are. They had to make sure some sort of damage (dog chewing, etc..) didn't cause them to fray. They really examined them well for quite a while.
Took my 98 OBW to the local Subaru dealer yesterday to plead my case for new seatbelts and, after a bit of arguing, they covered the replacement! I wish my powers of persuasion would've worked for the head gasket replacement a few months ago!
wheel bearing or tie rod issue?
revox replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the same issue on my 98 right now. I hear it more when I'm in a left-hand curve on the road. My friend is convinced it's the right-front bearing, but after jacking up the car and checking it (according to the Haynes book), it doesn't seem to be the case. I'm about to take it to the repair shop that has all my money.
Disappearing oil
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for all the replies. I've looked under it and everything is bone dry, but I'll check again tomorrow just to be sure. My driveway is cement (almost white) and I'd notice a single drop of oil. There's nothing at all. I'll change the PCV valve very soon.
Disappearing oil
Heya! Well, my 98 OBW (2.5) had the dreaded head gasket issue, so I had everything replaced (including water pump, timing belt, and 1000-or-so seals and gaskets) back in November. The car has been a dream ever since -- except one thing. My oil slowly disappears! I had an oil change in February and when I checked my oil yesterday it was almost at the "low" marker on the stick. My car doesn't leak a drop, it doesn't smoke, there's no oil in the radiator, nothing! So where does my oil go? Should I be worried?
99 Legacy - Is it worth it?
revox replied to dart67eb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe HG's are the only problem?? Heck yeah I'd buy that. I had my HG, timing belt, water pump, and 3 pages of other things replaced for $2200 (which seemed kind of high) a month after I paid $4500 for my 98. So $3200 for a great-running car seems like a great deal to me. I got ripped off by a local dealer, but I decided to just take the loss and get over it. I really love my car now.
Did my Good Deed for the Day
revox replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds a lot like the ad I answered (except mine is the much-more popular 2.5). They never did mention that the head gasket was blown, so I spent another $2300 on top of the purchase price on repairs and preventative maintenance. even though I was completely ripped off, I took full responsibility for my lack of judgment and now I'm in love with my car.
Roof racks for 97 Legacy GT Wagon
revox replied to dldunckel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI searched forever for a used Thule M.O.A.B. or a Yakima MegaWarrior at a decent price. I was about to give up when I discovered this extra-chunky rack from Rola (also sold as DrawTite) for $158 brand new. I love it, and it makes my soccer mom wagon (appear) a bit more rugged.
Anybody have pics of a 98 Outback with a Yakima MegaWarrior attached?
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a used (but in "great" condition) for $200 not too far from me. It even has the optional load bars. Looks pretty good on your car -- I might have to go check this one out. thanks!
I'm about to buy online but I can't seem to find any photos of one attached to my gen Outback. I find pics of the LoadWarrior, but not the MegaWarrior which is a bit larger.
Dash lights
revox replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbah! I should've known my good-for-nothing local Subaru dealer wouldn't have anything in stock. I ordered them for $3.99 each and I'll have them by Friday. Thanks for the numbers!
Dash lights
revox replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXare all the bulbs from the dealer the same, or do you have to specify what the're for when you ask at the parts counter? I'm asking because all of my HVAC lights, cruise control, mirrors, rear defroster, heated seats and windshield deicer are ALL out. One of these days I'm going to find the energy to take half the interior apart to fix them.
Door panel removal. Tips & tricks wanted!
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for the tips! oh, and I'm not installing tweeters, they're already there. I'm just swapping out the four door panel speakers.
You may or may not remember that in installed a new stereo in my 98 Outback a couple weeks ago. Well I quickly discovered that a couple of my speakers are blown, so I bought four new speakers and a box of Dynamat today. I can't seem to find step-by-step instructions for removing the door panels. Also, my car has tweeters up on the corner of the panel (where manual mirror controls would've been located on most cars). Is that tweeter attached to the panel or to the door? I'm just trying to get an idea of the scope of this job. I can have them installed for $80, but I'd rather save that money if it's a pretty standard job. if anybody can point me to a site with detailed instructions, I would very much appreciate it. thanks!
Stereo wiring harness - GONE! help!
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXokay, it's all fixed up and good as new. That was the absolute WORST amp installation I've ever seen. So many wires, so many butts & wire nuts, and all different kinds of wires spliced together. it's as close to being back to perfect as possible now. The new stereo (the double din JVC that Crutchfield insisted would NOT fit in my car) fits perfectly.
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh what a freaking mess! I'm at my mechanic's house having everything cleaned up. There's an Alpine amp under the seat that I didn't even know was there. Totally rigged installation! I've never seen so many spliced-together wires before. The nightmare will be over soon.
revox replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, that's what I'd like to do. You can buy the radio side of the harness all day long, but where do you find the car side? It really annoys me that someone would cut the harness connector out instead of just buying the part they need. People are so impatient.
