Crupper
Everything posted by Crupper
My 90 Loyale has a 4 sp auto and it will up shift to 3 rd and stay there, shift lever is in D and shows up on dash, but 3 rd also shows on dash. When I shift back to 3 rd or 2 nd it doesn't down shift. When trannie is cold it will act normal till it warms up and then it will down shift all on it's own and stay there. I pulled the pan and cleaned the screen. Couldn't find a filter. whatsup?
Is there a differance in the replacement of drive belts in a 89 Loyale and a 92 Loyale, both have carburators and AC units? the reason I ask is that I had both belts replaced in the 89 and now got a bid to replace both in the 92 and the price is about three times more for the 92. Thanks guys for any input.
OK. then this car's tire plate on the door post says 165 SR 13 and doesn't have a series. The the Goodyear tires on it are 185/ 80 R 13. Would that make it read more than 5%? I was driving my 90 sub at 55 MPH and the wife was following with this 92 and she was going 45 MPH. thanks for the comeback!
Just bought a 92 Loyale wagon AWD with a 3 sp auto and 185 tires and I see it came out with 165's and the speedo is 10 MPH off. Can you change gears in the trannie? The 185's are about new so didn't want to change back to 165's. Any suggestions?
OK thanks. Replaced the ECS (engine coolant sensor) and the blame thing still don't idle when warm. Runs great cold, till it drops to low idle and dies. I didn't replace the AAV, In Chiltons there isn't a picture of it, or how to test it, so don't know if it is OK or not. Or even if it might control the warm idle.Thanks for your help!
No, this THING is sitting on and is part of the thermostat housing. There is 2 numbers on it (1) 14467AA001 (2)A32-000 974 "JECS" Made in Japan. The radiator hose is attached to the housing. I took some digital photos but don't know how to post them.
Good advice! Found hose and found where to plug him in and got Turbo light,BUT she still no idle when warmed up. Must be the ECT, but where is it and what does it look like? Chilton's manual doesn't show anything like what is on top of this thermostat housing, It says to remove with suitable wrench and coat threads before installing. This I'm looking at has 4 phillips screws is square and on ohms check shows direct short at 100+º. Whatdoyouthink?
I forgot to say -- It's a MPFI motor w/turbo and auto tranie!!
My 90 1.8 w/turbo starts good cold and runs on fast idle til it drops off to regular idle and dies, it starts and runs above idle but the Turbo light doesn't come on when on a hard pull, now. When warm she no idle! Any ideas are wecome Thanks
My 89 Dl with spfi has a problem with the idle, when I'm stopped and the motor is up to temperature The idle speed goes up and down and doesn't stay steady. It doesn't have a Tach so can't tell how many R's it changes. Any help for it? Bob
Thanks, I'll stop looking.. I might try and hook a switch to the clutch relase lever.
I just bought a 89 DL wagon with a manual 5 speed. The blame thing will start (in gear) without the clutch pedel depressed. I looked in the Chilton book wiring diagarm and it shows no starter lock out switch, and it does show one on the automatic. Is this true? Am I looking in the wrong place? Help! The wife dern-near drove thru the garage door.
What a great group!! You guys did it again. Thats what is was!!! I put a hand vacuum on the can and the heater worked right, so traced out the line to it and it was hooked to a line that was connected to the air tube coming from the air cleaner. Tee'd into line at the intake manifold. Thanks a bunch
Had my hands on it the other day, but didn't take it off, I will take a closer look. Thanks
On my 90 Loyale I have lost the Cruse control and can't get anything but bi-level on the heater control, I've looked in the Chilton's manual but they don't show how either of them work, I don't know if it is a Vacuum or Electric problem. Anyone know how I might find this info, so I can trace it out?
Power Windows don't work
Crupper replied to Senor_reek's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had the same problem with my 90 Loyale, have checked everything for voltage and continuity, all checked OK. took the drivers door control off and spread out a clean cloth and took it apart and checked all the contacts they all looked OK but brushed them with a ss tooth brush, made sure everything in the right place and put it all together, installed it and everything worked. I have no idea what was wrong or out of place, but all the windows work, it's been driving me crazy for a month, I wish I knew what was wrong. -
I found the Window relay under the passenger seat and carpet in my 90 Loyale wagon, and after testing all the circuts, I have power thru the smaller relay to the bigger electric relay but no juice comes out of the other 6 connections on it. Must be where the trouble lies, dealer will have to order part and charge $139.00 bucks. Anybody out there have one in working condition, less expensive?
I got a 90 Loyale wagon with 4 doors and only the drivers door window will go up and down. I can get 12 v at all the other doors with volt meter but now enought power to operate the motors, I can jumper all the window motors and they work. had all the door switches apart and cleaned the contacts and they all work, so thinking it might be the window relay or controler. does any one know where they are located ? I"ve looked under the hood and under the glove box on the fire wall, but I don't see anything that looks like a relay. Any help would be appreciated
It is a 3 speed auto and a fuse for AWD, It has a push button to hold 1st gear. Been thinking that it does it more in AWD than 2WD. The drive line checks out OK, and the tires are all the same size, thinking it might be in the tranfer case doing something when it is in AWD. I'm replacing both front axles today, as the boots were shot for some time. I'm running out of options, checking the internet I can't find any rebuilt trannies for this model and so far no good ones from a wrecking yard. Everyone I talk to says "You don't have problems with this tranmission, there bullet proof" so I'm looking elsewhere. Open for any ideas from any one. Crupper
[quote name= Sounds like its time to look for a good used one. Gary[/quote] Where would be a good place to start looking for a good Auto trannie? "1990 Loyale AWD 5 dr wagon w/EA82 MPI Turbo", and what years will fit? Crupper
Bad news. Does the transmission come out by it's self or do you have to take the transaxle too? Crupper
The auto transmission on my AWD 90 Loyale shudders and shakes in first and second real bad when I start up from a stop. Has anybody else have this problem? Checked the fluid level and it was OK. Crupper
I just installed a "low milage" EA82 turbo from Japan in my 90 Loyale with AT- AWD. Got it running OK for a few miles ( 95 to 100) and now ATF is leaking down behind the engine, in front of the trans axle. Could it be the seal behind the torque converter? Do I have to pull the motor again? So far my wife thinks it's a pull toy as we have pulled it home twice. Now I know that if the horn that goes between the turbo and throttle valve comes loose it wont run long enough to get off the road. Volt meter works only when IT wants to, I check it when it is not working and altenator is kicking out 13 v. Not to worry?
After installing a "Low milage" E82 OHV Turbo in my 90 Loyale wagon, I see ATF leaking behind the engine, in front of the trans axle. How can that be as the Auto trannie is behind the trans axle? Would the seal behind the Torque converter be the problem? I put in a can of K&N seal softner in but that didn't slow it down. To fix do I pull the engine again?
It will only run for less than 30 sec at a time. I let it cycle a few times then start it up again, it runs smooth for around 30 sec then dies, not near enough time to warm up.
