goshorty
  1. Well I have located a good running 2.2 from a 01 impreza that I can get at a reasonable price. Ive located some 2.5's but there a little more pricey just wondering if a 2.2 would drop in there with out much additional work.
  2. I am looking at purchasing a 2001 Subaru Legacy with a 2.5 engine in it that has a rod hanging out of it. What would be my options as far as replacing with a new/used engine? I would really like to go with 2.2 but did not know if all the electronics and such would mesh up? Any input would be great.
  3. Been trying to figure out the 4wd on my 1991 Loyale 4wd with push button on the shifter. Ive found out i have a electrical problem and the vacuum solenoids are not operating properly. But I have switched the vacuum hoses on the solenoids so it should try to engage and the light on the dash comes on but it still acts like it doesn't want to go in. When you first let out of the clutch it makes kind of a grinding noise and is not in 4wd from what i can tell and if you gas it after underway it makes that same grinding noise. Any advise would be great it seems like the pin or whatever engages the 4wd is not being pushed or pulled far enough to engage it properly.
