intrigueing
Everything posted by intrigueing
  1. First check your tire pressure, then check tire circumference, new fluids may help, but often the cause is tire pressure or circumference problems.
  2. Did you set the crank timing with the line on the tab, or was that the one that broke off? I believe the crank position sensor gets its signal off the tabs, so if one is broken - it will throw the crank position sensor off.
  3. The crank has to be at 12'Oclock (and yes there is a mark below the crank sensor) but make sure you are using the right crank mark, you should use the mark on the back of the crank, there is a line on one of the notchy teeth (not gear teeth) on the back of the gear. Maybe someone can get you a picture. http://www.endwrench.com/current/winter02-03/EngineRepair.pdf has a picture, but it is not too clear. We are crossing our fingers for ya!
  4. First answering your questions: 1. You can compress them with a c-clamp just make sure to use the old pad to push on, sometimes I have just used hand pressure. Open the bleed screw and bleed the brakes after doing the brakes. 2. Replacing the fluid by syringing out the master is probably good enoughfor maintenance, however bleeding the lines is the only way to get all of the fluid out. If you are doing the front pads you might as well flush the lines. 3. Replacing the fluid like the dealer did is good enough for maintenance, but if you are doing the pads you will flush the lines out anyway. The dealer saying it is problematic to get air out of the lines while flushing is BS. You are pushing fluid through the lines, not air. And if that was the case how could you ever change a caliper? It is just easier and cheaper to do it that way - kind of like changing the trans fluid and not removing the converter, it is not worth dropping the trans to get every drop out during maintence, get most of it and call it good enough. Our brake fluid is hygroscopic, meaning it takes on water (so your brake components don't rust from the inside out). Replacing your fluid is done to remove the fluid that has taken on water, and to allow future capacity for holding water. Changing the Master will eventually work its way toward that end, just not 100%. But particles other than water tend to stay deeper in the system. I have heard of several people with ABS problems after compressing the calipers without opening the bleed screw. Changing the master fluid right before doing the brakes and compressing the caliper without opening the bleed screw will still push the crud in the line back through the abs unit. Solids settle to the lowest elevation, any rust and stuff will settle to the calipers, only flushing will take that away.
  5. I believe from another post (from memory) someone that did the AT-MT swap had to ground out one wire on the ECU that was creating the idle problem at temp, look around - or maybe someone will chime in.
  6. Try swapping ECU? May have a different fuel curve for AT vs MT after at temp?
