usps subaru
Everything posted by usps subaru
  1. Ignition relay sounds like something worth trying . Where exactly is that relay. I have changed fuel pump relay under dash. Battery cables are clean and I checked grounds under hood the usual ones are there and look clean and tight. I never thought about alternator I might have a used one to try.
  2. The problem started with the engine just falling on its face no throttle response at all but the car did not shut clear off after afew seconds it would regain and throw you back in the seat. Now the car is shutting off sometimes when this happens but i still have all electrical power. seems to start right back up.
  3. Yes check engine light on code says oxygen sensor and lock up torque converter in trany. I gutted catalytic converter wasn't sure if light would ever stay off now. the lights in dash do not come on when it shuts down and comes back on its own. I thought maybe switch so i wiggled while driving nothing unless you shut it off then lights come on as usual. I have tried wiggling wires under hood not much under dash i'll try that too.
  4. I purchased a 95 right hand drive subaru legacy and i've been having trouble with it shutting off or loosing all throttle temporarly then regaining again. I have changed plugs ,wires ,fuel filter, ignighter, throttle position sensor, idle control, cam sensor, crank sensor, knock sensor, fuel pressure regulator, coil, timing belt, belt tensioner, oxygen sensors, fuel pump, fuel pump relay, mass air flow sensor, and the ecm. If any one has a suggestion to try I am really open.
