sa997
Everything posted by sa997
  1. Hey. About the clock rpm. No more than 1000 rpm. Could be a few days a week, the clock works fine. The rest was invalid .. First of all (this is manual Impreza 1994. injection.) 1. The problem began when my mechanic did treatment 10000. And where did wash engine with degreaser and water. 2. I noticed when I turn on Swatch. Engine is turned off. The merger is above 0. About 4 Malimter. I know I turn on the vehicle. Time columns do not exceed 1000. I noticed that the most important detail. I travel in this state. I hear rings of ignition. 3. If lighting Suwetes. (engine off) hand column is 0. I turn the engine. Tory clock works fine. Everything is fine. Even with the air conditioner is turned on Why am I complaining? I travel with an air conditioner. Clock rpm. Does not exceed 1000. I stopped at a traffic light. The engine stutters And rings off. turns on a lamp to me. Check engine. Do you have an idea? . With thanks to Shlomi (through the back. I replaced ignitor and it did not help)thanks
  2. . I have a Subaru Impreza 1.6 94. I have two questions. Social the plugin. Black and showed error 35. (canister). I checked it and it correctly. 44 Om. He closes vacuum. Opens, and no liquidity. I did a test with the green connector. Travel in all normal. I wanted to delete the problem connecting two black authors black and green to green. But the problem is not deleted. This is a problem because I have error traveling with Air Conditioner. After 10 minutes. The engine stutters. Check lamp turns on my engine. 2. How can I. As properly since Solenoid valve
