Posts posted by dasbrat
Yeh, it might be a vacum problem, but I've checked all the lines and they seem to be O.K. It just doesn't make sense. It worked fine the last time I had it out, and I've done nothing to it!:-\
Hey Gang, got an E-81, 81 Brat, runs fine, starts easy, but it won't idle,.. has new plugs, air filter, and clean gas. It ran and idled fine the last time I took it out, but now it dies every time you let off the gas, what's up with that?
Thanks
Short and Sweet,. will rotor's from a 1979 Brat interchange with rotor's on a 1981 Brat?:-\
Thanks
Bolt one on and find out
Even if you buy the rims and they have too much backspacing; you could turn them around right here on the USMB.
Still dealin' one the car at the JY, and I think carfreak85 may be right about the backspacing issue. I guess I can always use them on my 82 Brat
Right?
I have an 1981 Brat, just found some good lookin' 14" alloy Pug's on a 1979 junkyard sedan: First, will they fit or will the offset be too much? I did a search on USMB and couldn't find enough to clarify exactly what wheels, and tire sizes would fit on my 81 Brat without a lift, or at least doing some cutting? The fender cutting would be O.K., but also can't find enough info on a lift for Gen 1's.
Thanks for a clarification on what size wheel and tire works with a Generation 1 Brat.
Thanks gang, I'm pretty sure the carb is a Hitachi. I looked at the PCV valve and its was plugged to the hilt! I replaced it and cleaned the hoses out, but alas--no difference with the smoke! I think I'm going to re-toque the heads, throw in some Marvins Mystery Oil or Sea Foam and hope for the best!
I keep you'all posted at to the outcome.
Thanks gang, I just wanted decide where to begin the repairs,. i.e., re-torque the heads instead of replacing head gaskets, etc.! Don't want to spend a lot of time on money on the wrong fix!
During my message board search I found a thread that said
Does anyone know about this? At this link: http://www.ultimatesubaru.org/forum/showthread.php?t=26199&highlight=white+smokeThe Hitachi has a section that attatches to the manifold where coolant runs from the manifold to the carb. The weber has no such port, so you need to make sure its blocked off good or else coolant will leak into the intake, it would cause the problem you describe.Thanks again, and no harm intended to actual Gremlins:D
O.K., first time poster long time member Tried the search and research method but still puzzled so now I’m asking for some advise! I have a 1979 GL Brat that smokes like a freight train when you start it up,… but only 4 out of 5 times. It takes it forever to warm up, and once it does there is bubbles coming up in the radiator. I know this usually means a bad head gasket (cracked head or block), however, the oil on the dip stick looks as new as when it was changed, last year! Which is really puzzling since when you take the breather cap off, you can hear an air sucking noise and you can see something being spit up in the pipe, can’t tell what it is? The smoke coming out of the exhaust pipe does not have a sweet smell to it, in fact the smoke has a very light bluish white color to it, tons of it, for about four minutes then it goes away, and all that is left is a clear liquid dripping out of the tail pipe? Plus, my radiator fluid level doesn’t really seem to be dropping, especially considering all the smoke! I’m just not sure what to do first to find the Gremlin in my Brat,.. thanks for all your help!
Won't Idle
Posted
Guess I'm going to have to find a manual! Don't know where to look for a "idle air control valve?" Can you decribe it? If that's the problem, what's the fix? I don't need this to pass emissions.
Thanks
