SubieTony77
Everything posted by SubieTony77
  1. Cougar, the switch was one of the first things that I checked and replaced, they are notorious for going bad, however, it was a connector that came apart inside the door. There was a window replacement TSB about the new wiring being shorter than the original and it could work itself loose, and it did. That was the problem, thank you everybody for your help.
  2. ocei77, I will check it out, and Cougar, or whoever else reads this, when I hit the window switch it doesn't make any noises or clicks, it is as if it is not connected. So I will check the motor, thanks for your help.
  3. OK, I need some help, I have a 2002 Impreza Outback Sport, and my drivers window does not work, it is not the switch, and I would assume that the relay is bad. If anybody has any ideas on what else to check, or where the relay is located, I would really appreciate it.
  4. And that information is identical to what I have been finding, I do appreciate the coordinating information about the platforms. Thanks much. -Tony
  5. This was much help, I will cheerfully use the information you have so graciously provided. In my manual transmission class we just had one of these apart and rebuilt it, so it looks striking familiar, all except the extra gears, have a great day. Cheers, -Tony
  6. Thanks much, I did find that just a little bit ago. -Tony
  7. This is exactly the kind of stuff that I was looking for, you guys are awesome, and I am at Muskegon Community College, my teacher is going to Ferris though. Thanks much.
  8. I appreciate the help and input, however, I need to address one transmission, and the 5MT is what I picked. Again it just needs to be a basic paper, with a touch of evolution.
  9. Hello everybody, my Name is Tony, die hard Subie fan, I am in college for an automotive technology associates degree. I am writing a paper, simple one, about the 5-speed manual in the 1999 Impreza Outback Sport. I am finding information a little scarce, such as, the models this was used in, and reasons for changes in gear ratios. So if any of my fellow Subaru people have any information, or advice I would greatly appreciate it.
