Posts posted by SubieTony77
ocei77, I will check it out, and Cougar, or whoever else reads this, when I hit the window switch it doesn't make any noises or clicks, it is as if it is not connected. So I will check the motor, thanks for your help.
OK, I need some help, I have a 2002 Impreza Outback Sport, and my drivers window does not work, it is not the switch, and I would assume that the relay is bad. If anybody has any ideas on what else to check, or where the relay is located, I would really appreciate it.
The AWD 5MT was used in everything that had a manual transmission (in the US).
Gear ratio changes are based on the vehicle power, weight, tire size, and how sporty/economical Subaru wanted that model to be. They are completely variable and transmissions can be found that run the spectrum from short-ratio sports car gear ratios that top out at 120 MPH to ones that are designed for longer ratios that provide better fuel economy.
It was a standard platform that was used on all manual transmission Subaru's - you can't really tie it down to the '99 Impreza OBS.... that same basic unit is still being used - it has been almost unchanged since 1990 and it derives it's basic design from the part-time 4WD 5MT's first introduced in 1985.
GD
And that information is identical to what I have been finding, I do appreciate the coordinating information about the platforms.
Thanks much.
-Tony
Also include some argument in there about how america missed out on the dual range AWD gearbox from the EJ series making note of how this would have benefitted many subaru fans as found on this site.
Here's a pic of an EA82's dual range 5 speed gearbox (85-94 model run) front section, the rear housing has to be removed to get to the front casings to split them like this:
And here is a '94 model liberty/legacy AWD dual range gearbox, rear housing removed again to get to the front cases to split the gearbox:
What are the differences you ask? Apart from some slight changes to the front casing design for bolt stud patterns, the rear housings changed to accommodate the centre diff (but retained the same rear bolting pattern )
The top image is the PT4wd gearbox derived from the L series. On the other end of the pinion shaft from the diff is the gear that powers the rear end once the engaging mechanism locks the gearbox to the rear drive.
The lower image has several splined shafts that are stubby compared to the length of the shaft with the gear on the end of the L series' gearbox. This is because the lower gearset is effectively mounted on a tube that has the pinion shaft pass through it to the front diff. This allows the pinion shaft and the lower gearsets to spin at different speeds independently of eachother.
The splined ends opposite the diff is where the center diff mounts - the spline on the far left is the pinion shaft and the spline just to the right of that is the lower gearset that drives the centre diff before power goes to the front and rear as derived by the centre diff.
Ultimately the the overall design of the gearbox remains unchanged until you get to the six speed gearbox. The US market didn't get the low range gearing that you can see mounted above the front diff, so there's only a straight shaft in there.
As you've already mentioned the gear ratios do change - this will be determined by which model the gearbox was destined to be in and what power plant was mounted in front of it as well as the market demographic it was aimed at. Probably all the things you're looking at in your paper I would imagine.
I hope I haven't wasted your time with this essay on what we've got over here in comparison to what you received over in the US, but I thought it might have been useful/interesting.
Cheers
Bennie
This was much help, I will cheerfully use the information you have so graciously provided. In my manual transmission class we just had one of these apart and rebuilt it, so it looks striking familiar, all except the extra gears, have a great day.
Cheers,
-Tony
wiki has a pretty good sized write up on the subi 5mts if you havnt ran across that yet
Thanks much, I did find that just a little bit ago.
-Tony
He is a student at ferris.
This is exactly the kind of stuff that I was looking for, you guys are awesome, and I am at Muskegon Community College, my teacher is going to Ferris though. Thanks much.
I appreciate the help and input, however, I need to address one transmission, and the 5MT is what I picked. Again it just needs to be a basic paper, with a touch of evolution.
Hello everybody, my Name is Tony, die hard Subie fan, I am in college for an automotive technology associates degree. I am writing a paper, simple one, about the 5-speed manual in the 1999 Impreza Outback Sport. I am finding information a little scarce, such as, the models this was used in, and reasons for changes in gear ratios. So if any of my fellow Subaru people have any information, or advice I would greatly appreciate it.
Subaru Electrical/ window
Posted
Cougar, the switch was one of the first things that I checked and replaced, they are notorious for going bad, however, it was a connector that came apart inside the door. There was a window replacement TSB about the new wiring being shorter than the original and it could work itself loose, and it did. That was the problem, thank you everybody for your help.
