smcphc
  1. Cool beans, I found this thread http://www.ultimatesubaru.org/forum/showthread.php?t=12947 Hope this is it. My wife is looking into trading this in on a Mini Cooper if it lets her down again. Then again... Thanks everyone for pointing me in the right direction.
  2. OK, I got it to not start, didn't see spark. I checked the connections on the TPS, plugged everything together, and she started up. I checked the OBD II as I noticed the check engine light and got a P0335 Crankshaft Position Sensor A Malfunction error code. Off to do some research on that. Scott
  3. Thanks-Still trying to get it to not start. I don't think I ever wanted a car to not start before, it's tough to troubleshoot a car that seems to be running fine.
  4. New to the forums, my wife and I are the original owners of a 1996 Legacy Outback 2.2 5 speed, 110,00 miles. Car has been basically trouble free except for having to replace the oil seal. Anyway, it's my wife's commute car, and recently it started misbehaving. It's a random occurence, so hard to troubleshoot. When it happens, the car will turn over but not start. If you give the throttle linkage a flick by hand, the car will then start. I kept the car for a week trying to replicate the problem, but it worked fine for me. Yesterday it happened to my wife and as I had to meet her in a parking lot while I was on my way to work, I didn't have time to properly troubleshoot it to see if either the accelerator or cruise control cables were sticking. The flick thing wasn't working for her, but after I showed up 10 minutes later, the car turned over but wouldn't start, I gave the linkage a flick, and she started right up. I did a basic forum search and didn't see anything similar. The only other known condition with the car is the check engine light popping on every so often with the P0115 Engine Coolant Temperature Circuit Malfunction, which either goes out by itself or needs to be reset. Thanks for any help. Scott
