Everything posted by hal1971
Fuel starvation after replacing fuel tank
hal1971 replied to hal1971's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA little update, Had to go to a subaru dealer for a recall. Since I was there I asked them to check my tank installation, they analysed the check engine code and told me it was surely a cable piched under the new tank. a 4-5 hour job to check at 110$. So I asked them if I can continue driving without my gaz cap and they told me that it's not a problem. I'm driving like this since then and car's running fine.
hal1971 replied to hal1971's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid not have the chance to bring it where they installed the tank and frankly i'm not sure I want them to work on it anymore. If it's the breather line, is it a costly job to have it checked ? I'm still running with no gaz cap, everything seems to be fine.
hal1971 replied to hal1971's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm very unlucky with this car, each time I go to a shop for a fix, I have to return because something is wrong. Is Subaru so hard to work on I'm in the process of buying a new sub, I will leave the old one at the shop so they can check and recheck...
Gasoline smell--outside of car
hal1971 replied to ltk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had to replace my fuel tank on my impreza 2002, the tank leaked when it was more than a half full. It started with a litlle gas smell, but a few month later, that smell was very present.
hal1971 replied to hal1971's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hope they checked that, because I had to return twice, the first time they told me they did a shampoo and it was condensation, the second time, they told me it was the gas cap. Do I really have to buy a Subaru Cap or I can go OEM ?
Just before christmas, I've replaced the fluel tank on my impreza 2002 TS hatchback. The fuel tank was almost empty, after the replacement, I did 10-15 miles driving without problems. The trouble started after fueling the car full. after 1 miles of driving, the rpm was going up and down, the car was stuttering and shaking. I was able to drive home and tested the car a low speed with this problem happening more ofter. The next morning I started the car and leave it heat for 10 minutes and when I stepped on the pedal, the car died... So I called the mechanics to have my car towed so they can check the trouble. after verifying everything ( emptying half the tank doing so). They told me it was my Gas cap that was broken and gave a generic one. With the new gas cap and half a tank, everything was fine, car running great. I did almost 250 miles, but being not sure of the gas cap problem, I never fulled the car full, always in the half 3/4 range. Last week I fueled the car full, guest what, starvation again... For now i'm driving without cap and everything's fine, I have the check engine led, but car running great. A original gas cap cost 35$ buck, the dealer needed my serial because they where 2 kind of cap that year and told me I SHOULD by an original... My question: Can a broken gas cap do this kind of trouble ???
