goat
  1. gross Gary like your style done that before as well most notably in a school buss... but the car in question is at the top of a long and steep and rutted and windy dirt road and it's been raining for days... anyway -- l got the piston out and could have rebuilt it but the useless employes at the Mckrankin franchise couldn't find or didn't have a rebuild kit and the seal got damaged in the extraction so there's a new caliper on there (and the other side got its sliders greased -- which it needed badly) did l mention it was raining and l was in a dirt (that is mud) drive way what fun thanks for the help goat
  2. yeah l took it apart the slides are ok piston won't comprest... haven't tried pumping it out cuz this is the only car available for driving to the auto parts store... guess I'll buy a caliper and a rebuild kit return the one l don't use thanks goat
  3. that's what l figured... prefer to rebuild things -- rather than just replace but not this time rotor looks fine... thanks goat
  4. good day all its been a long time... l'm visiting a a friend and naturaly her car needs work.... it's a 96 legacy l driver side brake caliper is stuck (has been for a while judging by the diferential wear on the pads don't have a shop at my disposal here -- how do l un-stick the piston? or do l just replace it? thanks goat
  5. l was thinking along the same lines dont know what the gasket should or would look like (dont know what happened to it when l first took the tank off) is rtv an anarobic sealant (im thinking not...) thnaks goat
  6. thnaks every one wasnt to worried just curions
  7. so l found this adjuster looking screw under the intake manafold is it important? any idea where it came from? thanks goat
  8. good day when l did the oil seals and timing belts on my 92 loyale about a year ago l mistakenly took the reservoir off the ps- pump and now it leaks alot l have replaced the o-ring and searched for a gasket to no avail any thoughts or clues thanks goat
  9. good day all its been a while sincel was on here but my sweetys 92 loyale is acting up here is her description: so for a while now the car seems to get stuck in high idle when I start it up and go down a big hill in first and second gear. It revs very high for a bit and then normalizes when I'm on the road in a higher gear. It may be fine all day with no signs of problems, but lately it has been idleing erattically when I am sitting in traffic, higher then lower then higher then lower...etc rapidly. When it is doing this the check engine light comes on, but when I get going again the light turns off and the problem goes away. l've been tryign to serarch but not finding many similar threads... thoughts sugestions places to start thanks goat
  10. thanks ya'll it's an ongoing problem (which is what l meant to imply, by mentioning the po had the same problem) l'll go through the "procedure" 86gl-10trbosdn laid out and report the results.... wont be for a week or so cuz l'm out of town and my lady isnt very mechanically inclined tundrabrat thanks for the offer l'm afraid l'm not who you think l am and am far away in california a garage to work in would be lovely though oh well milesfox teh symptoms you described dont quite match up but l'll ask about that too thanks again goat
  11. the tires are fine old but not unevenly worn..... l'll take a closer look when l get a chance though (out of town at the moment) though l seem to remember my mom complaining of the same thing (the car was hers until fairly recently) thanks goat
  12. good day my 92 loyale feels unsteady/whishy washy not like steering wheel play or drift more like it feels like it wants to slide out while cornering (and not under hard acceleration either) sorry l cant give a better description, it's my ladys car so l dont have much first hand experience she says it feels less bouncy/handles better when in 4wd.... l dont know anything about suspension so how do l go about checking/troubleshooting thanks in advance goat
  13. l re engenered the bracket but just a tiny bit used apiece of gas pipe as a spacer and a (long)bolt nut washer to hold ti in place is working fine and l ran with out said contraption for a while with no ill effects cheers goat
  14. yep cv it is found the leak cleaned it and attempted patching with RTV we'll see if it holds if not l suppose l'll try a split boot any recommendations? also as per my other question about the missing trans oil dip stick the numbers l found on the trans are as follows 464794 AW-TW75F5A2BV so if soemone with the same trans would measure their dip stick and the fill lines that would be great thanks goat
  15. it does seem like axel grease black and sticky there was alot of it on the cross member and l wasnt sure if it was from the previous oil leak (got the car with the oil leak cuz the po didnt want to deal with it) and l pressure washed it the fire wall and cat stayed clean till it got driven cross state then then towards the end of the drive there were weird swishing sounds and when l took a look new splatter l'll look harder at the cv boot (and probably ignore it til it starts making dry noises) l dont know which tranny it is 5 speed manual l'll look for numbers next time l get a chance (it's my lady's car now) thanks goat
