Posts posted by 4x4brat
Dry Throw out brearing:mad:
if you need help machining some from raw urethane
let me know
Welcome Capt
Great group of people and Super Information!!
Who has a good pattern? or a old one in good condition?
Who Else?
tony5143
biffanyus
0225wrx
yellowsub
bendecker
master cylinder?.....
NO one has ideas?
or do you..like me...... just do not know!!
grrr:-\
1983 brat with hitachi and A/T
1st :-\
I need help with a ECM code 22...... vehicle speed sensor
where is it ? how do in check it ? or replace it?
2nd:-\
i have no dash lights or running lights.....
fuze #12 blows when installed
Where do i start to look to find short???
Any help Would be Greatly Appreciated
It Sure Looks Kool but I sure do not plan hauling it this way
is a 154" long track.....
A short track would fit great!
Yes its on top of the wheel wells
you can put in longer studs......better safe then.........
i got an 83 brat with electric HEAD LAMP issues
passenger side works fine
drivers side low beam is dim and the HI beam will not work at all:-\
any help/ideas would be GREAT
Thank You
A few more takers??
i could water jet them out !!
i got some front half shafts..... and 4" lift kits cheep
I had them Nickel Plated this RUN......Get YOURS........ Order Today!!!
:eek: "WHILE THE SUPPLY LASTS" :slobber:
tap out will eat the bolt and hardened steel and not the aluminium!!
Works great!!
try.... tap out!!
well after looking at my other brat i notice that the new rotors are 1/8" thicker....grrrrr:mad:
this is causing the rotor to hit the brake pad hanger and stops the rotor from spinning
anyone have this issue or seen this problem with the older gens?
Thank You Brian....(subarujunkie) for bringing me out the cone washer!!
after replacing with all new front end parts
i tighten the axle and its causes the rotor to rub the brake pad hanger
any ideas?
Thanks for your help!!
Who heard of such Thing?
Cocanie.........Sniff...sniff:eek:
replace the damaged head with a GOOD one
save your self the head ache
whats one worth to ya with tinted windows?
LUG NUTS FOR PEUGEOT WHHELS ON 82 BRAT
Posted
i got them
