jc50942
Posts posted by jc50942
just like a plain flat washer with rubber in the middle..
thats what i thought at first...but they dont quite fit right, and there arent enough of them, and there werent any there when i took the valve covers off...i know there usually are...but the h-6 must be different.
check to see if the ac compressor is actually engaging. If its not...start checking fuses.
did heads on an 02 outback h-6....there are 12 of these in the head kit...anyone know what these are for?
Crap so a cross country trip would be a very bad idea on that belt
personally a trip across town would be sketchy
Looks worse on pic than in person since its so close up
i had one last week that looked just like that...didn't break, but the teeth on the backside of the belt were coming off...crank was turning but the cams were not.
IMO if you dont know the milage...replace it..and alll the pulleys and water pump. It will end up saving you the trouble of doing valves down the road if it does break. Ive seen too many ppl get rid of nice cars that they liked cause they didnt keep up on the maintenance and "took a chance". Just my two cents.
well..got the heads of..this is what i found on the intake side of the passenger side head.
there is so much lip from the wear that i can even get the lifters for the number 1 cylinder out on the itake side....oh well...its only money
Im just really suprised that there was no noise coming from that. Any that i could hear anyway.
ive come across this a couple times...for me it was always that little secruity button that is taped under the dash.
im supposed to be pulling 17 inches of vacuum at this sea level and im only getting 13 so yeh...crappy...never thought to check to see what vacuum was...kinda makes me feel dumb.
ok...so i let the car sit for awhile...come to find out i dont have the right adjustment on the valves...so the heads are coming off...supposed to be .15 on the intake and .20 on the exhaust...i got .03 and .08 as an average between the three cylinders....good times.:-\
i know for a fact that im not off...had it apart three times...after the new chains went in...lines the links up exactly as put forth in the service manual.
i suppose i could either swap those too...or find out what they are supposed to ohm out at and check that....the thing that really gets me it that it feels smooth when its missing...almost like a false code....it was running really bad before i put the new chains in...im still getting the same codes but it runs smooth.
injectors?
yeh..injectors...i dont know about subies...but i know on gm's, if one is shorted, it will take that whole bank out because of the way they are wired.
im not arguing with you...im gonna do it myself...but what will a comporessing test prove that a leak down test wont..except give actual numbers...it no air leaks through anywhere when the valves are closed...then what is it that you are looking for? Like i said..not arguing...just learning from someone who obviously knows more than me.
i honestly dont know what the numbers are...i didnt personally do the test myself....the shop foreman did while i was on another project. As far as the coils go...i did swap the coil from numer 1 and 2 to see if it changed anything...no change...possible injectors or that circuit?
yep...all on the passenger side...so i was thinking maybe some kinda issue with the coils...which are also new...but something from the computer to the coils? Which doesnt make sense to me casue then it should do it all the time...not just after it gets warm.
new chains...still missing on 1, 3, and 5...after it gets warm...leak down test was good...coils, boots, plugs all new....im outa ideas. Anyone run into this?
if it was up to me i would've already...but the boss is a cheap rump roast and someone told him it wasnt required...soooo no. But its gonna get done monday.
well...leakdown test complete...no bent valves...gotta be a stretched chain.
well...before i start tearing too much apart...im just gonna stick a camera in the plug hole and see whats up...and by the way..i dint expect to get this much help...you guys are awsome.
Doing a valave job at that mileage makes me nervous, but hey, not your car
why is that bad? is it a subaru thing? worried about the bottom end im assuming?
cant help when the boss is cheap...but what do ya do? I told him everything should be replaced...but whatever.
anyone know what this is?
Posted
it was a set straight from the dealer.
