tehP
Posts posted by tehP
Hey gang,
Just want to be super confident before I make the investment.
I'm refurbishing my new '96 Legacy OUtback Wagon, 2.2L. ~200k miles.
Runs great! Fixed up exuaust, brakes shifter linkage, etc etc.
I need struts in front and back.
I'd like to start with the back simply because it's cheaper.
I also want to get an alignment after I do the front, and I don't have
the cash for that right now.
Can I get away with $95/pair "APX" struts on ebay?
I don't do any offroading. Just looking for good cheap struts for city and highway driving. Again, bonus for cheap-but I don't want to get total crap.
$95/pair seems cheap, when they go for nearly $100 each from both Subaru and auto parts stores.
Thanks in advance I appreciate it.
I know this has been discussed, but I'm just looking for first hand accounts so I can be confident before plunking down the cash.
~p
Just wanted to give an update on my shifter.
The TL/DR version of below is simply "I was sold the wrong linkage, tore mine apart and replaced the all of the bushings, and re-assembled the whole shooting match with nuts and bolts instead of the factory spring pins and rivet".
This post details my struggle, and lists all Subaru part numbers
as well as some photos.
I simply wanted to share my struggles and hopefully save somebody
a little pain, and the $60 of purchasing the incorrect linkage.
Here's my linkage on top, and the new one on the bottom. Ugh.
http://dl.dropbox.com/u/42779/Gallery/right%20vs%20wrong.jpg
I didn't make a full "walkthrough" as an excellent one by "doc526" exists here:
http://www.ultimatesubaru.org/forum/showthread.php?t=113480&highlight=shifter+bushings
Learn it live it love it. Make SURE you have a 10" socket extension and the proper
punches BEFORE you begin.
Yes, it was a *************** to get this job done.
**If your linkage has a "neutral return spring" mount hole
like mine, your replacement linkage part number is 35047AC010.
If I had a bottle jack/transmission stand/similar (and a 14mm deep socket…) I ABSOLUTELY would
dropped/moved the transmission. Dropping the tranny will give you a straight shot at the spring pins.
That's the only hard part about this stupid job.
Borrowed ramps from the building super. Drove car up on ramps.
Chalked wheels. Got comfy under the ***************.
Working on the street, I put cardboard down under all the "trouble" areas,
as I was certain I'd inevitably need to use large amounts of penetrating oil.
I was right about that! Plus lying on cardboard is nicer than 40 degree
pavement.
I was smart enough to start shooting the linkage with PB Blaster the week before
I began this project. My linkage was basically FUSED to the transmission so try
to focus some at that joint.
Again, here's the hard part.
One cannot get a straight shot with a punch at the spring pins. It is impossible as
your transmission is in the way.
This is where you should ABSOLUTELY drop the transmission enough to get in there.
I unfortunately had two issues preventing me from doing this; 1, I didn't have a 14mm deep socket.
I could un-button all but ONE of the transmission mount bolts (!). Second, I didn't
have a real secure or smart way (transmission table or bottle jack) to support the transmission. A stack of 2x4 chunks
isn't the smartest or sefest, Plus the *************** is heavy to shove back into place. So take it from
me and don't do it that way.
But using my method, I was able to nudge the transmission about 1/2", enough
for slightly cleaner access to the pins.
Using a motley assemblage of a punch, socket, universal socket joint,
and a 10" socket extension (held together with electrical tape) I was able
to hammer the piece of ************ pins out. Again, read doc526's walkthrough for a description
of the punch setup.
Once the pins were popping out the top enough to get a vicegrips on, I was able
to negociate a smaller one in there, clamp down, and pound on IT with a socket
extension to pop the pins.
There are two spring pins, one nested inside of another. You have to use the smaller
punch to knock the little one out first. Then the larger punch for the second, bigger pin.
I ended up having to use a torch on the transmission shaft the linkage
sits upon. After a good 30 minutes of hammering on that with a 5lb drilling
mall and a big concrete chisel, I was able to get the old linkage off.
Luckily it's a tough part so I didn't bang it up too bad.
Here it is just before the last pin was knocked out:
http://dl.dropbox.com/u/42779/Gallery/linkage_mount.jpg
Here's the gnarly old bushings:
http://dl.dropbox.com/u/42779/Gallery/Old%20plus%20bushings.jpg
I spent nearly an hour cleaning the shifter arm and all of related bits.
I re-greased the bits which needed grease. Make sure you do this.
This is also the time to replaced the 4 other bushings.
http://dl.dropbox.com/u/42779/Gallery/Shufter_Part_Numbers.tiff
Inside the shifter assembly, I removed the wire-clamp, pulled the shaft it out of
the rubber boot and replaced the big white bushing , #35035KA010
http://dl.dropbox.com/u/42779/Gallery/shift_bushing.jpg
Lots of grease. Buttoned it up and cleaned everything.
I didn't take photos of this for some reason
Much to my amusement, the Subaru dealership had sold me the incorrect
linkage. Luckily, I threw out the plastic baggie it came in so they won't let
me return the $60 part.
The internal bushings were all shot causing a huge amount of slop.
I'm nearly positive the way to determine WHICH linkage part # you need is simply based
upon whether yours is equipped with the "neutral return" spring or not.
This spring attaches to a washer with a tang and to a hole the linkage.
My spring was missing of course, but I was wise enough to order a new one
just in case.
Here's how I rebuilt my linkage. It took some time and I had PLANNED
on replacing it anyway. If I had to do it all over again I would STILL replace
the part rather than rebuild the old one, but it isn't necessary. A bit of time
will save you a $60 pain in the rump roast part.
I cut the head off the rivet holding the mess together (see photo link below) with my Dremel+cutoff wheel.
A trip to the hardware store later,
I had a 3" 5/8" bolt, a 2.5" 3/8" bolt, two nuts, two nylon lock nuts, four flat
washers and four lockwashers. I used locktite on the bolts too. I realize it's total
overkill but I'll be damned if I'll have those stupid bolts backing out and flying off while
my wife is driving on the Brooklyn Queens Expressway, dodging tractor trailers and taxicabs
without the luxury of "changing gears".
The 3" 5/8" bolt rig replaced the rivet. The 2.5" 3/8" bolt rig replaced the spring pin ************fest. I believe
I cut down both bolts to fit a bit better with the Dremel+cutoff wheel.
I strongly recommend you do the same in case you have to pull yours out for any reason.
Which I of course had to do after assembling something incorrectly! My god If I would've
had to get those spring pins out again I think I would've lost it.
Heres a photo of the linkage indicating the rivet and the spring mount hole.
http://dl.dropbox.com/u/42779/Gallery/Linkage_rivet.jpg
Got it all back together - feels 100% better. Something STILL isn't quite right as it
doesn't "stay" in first or second gears. But at least the stick returns to neutral.
My wife can drive the car now
And I haven't missed 5th gear/hit 3rd since. SO I think i'm in good shape.
Pretty sure I simply put the big washer with tang that the "neutral return spring" attaches
to back on incorrectly - it's under quite a lot of spring pressure at all times.
But I haven't had the heart to climb back under the ***************
Here's the correct parts diagram taken from Opposed Forces.com (http://opposedforces.com/parts/legacy/us_b11/type_44/manipulation/manual_gear_shift_system/illustration_1/).
I've circled the parts I replaced.
Full part numbers: bushing #35035A in diagram = subaru part number
35035AA030 "Sport Bushings" - Buy 4 of these.
44044AA010 "Spring" - Neutral return spring.
This is a two hour job if you 1) move the tranny and 2) do your homework and have the right parts on hand.
I could only nudge #1 and as hard as I tried, I failed at #2. Luckily I was able to make it work.
Since this job, we succesfully drove our "new" '96 Subaru from Brooklyn NY to my Mother in law's in
Rockville Md, outside of Washington DC.
I did this job, as well as bled the brake system/changed brake fluid. She also received a new
stereo (bluetooth hand free calling FTW) as well as front speakers! Looks pretty good.
http://dl.dropbox.com/u/42779/Gallery/stereo.jpg
That cable coming out is the microphone for the hand free calling setup. Gonna re-route it up the
vents or something.
It's about a 400 mile drive and the car performed FLAWLESSLY.
I was very impressed. My gas mileage consistently improved, too; first tank was 22mpg; second was 24.5
and the last was 26.5!
Plus we brought this guy home
http://dl.dropbox.com/u/42779/Gallery/nico%202.jpg
Having a car allowed us to pickup the dog outside Philly on our way
back from DC. sure beats AmTrak or a grayhound.
Since we got home I did a SeaFoam "crankcase" treatment via the PCV valve (with some in the gas).
She was starting to idle a bit rough, and for some reason wouldn't drop below ~1k RPM. The SeaFoam
totally fixed my idle and it feels/sounds great.
It poured out SO MUCH white smoke it was like a goddamn smokescreen! I took it on Ocean Parkway, a sort
of mini-expressway, and drove at high speed. The drivers behind had to change lanes to see! This ended after
5 mins and the car has been happy since.
While I was pulling vacuum hoses to dump the juice in I found the inside of the vacujm hoses are deteriorating!
Black rubber gunk has collected in those hoses, which I believe is greatly restricting airflow.
I cleaned / sprayed them out the best I could and re-assembled. So I'll be replacing those hoses.
I've already got ~1500 miles on her since I bought it, so I'll be changing the oil again.
Next up : struts in front and back, as well as the "power steering gear boot" on the driver's side.
Got a part on the way. I don't think I need to replace the tie rod.
After that I'm gonna take her in for a front end alignment. It's actually really great in terms of alignment
but has a SLIGHT pull to the left. So that will be a good time do do it - figure it will need
it after I pull that tie rod/replace the struts!
Thanks and please let me know if you have any questions about any of this. I'm by no means
a master mechanic but I'm learning.
Forgot to ask again,
How do I know if my tie rod needs to be replaced? Can I determine that before I tear the front suspension apart? I don't have another car is the issue.
Here's a (poor quality) photo of my boot tear. It's ~2inches, and vertical on the Left power steering boot. I can see shiny, not-rusty tie rod inside. I don't see any grease, however. should I shoot some grease up in there for the time being?
https://p.twimg.com/AndFlIdCAAAfkpZ.jpg
Should I buy the inner+outer tie rod parts "just in case" to have on hand?
Or should I simply replace the "power steering gear boot" and put the old tie rod back on?
I don't mean to be a pest guys, and I really do read/search.
I know what parts are involved, their names, what they do, generally how to pull them off and put them back on.
But I'm working outside in a big city, in the cold, and with not a lot of experience. It really helps my confidence to hear from somebody whether I'm barking up the wrong tree or not
You guys' guidance has brought me a long way already-couldn't have got this far without USMB.
xox
Driver's side is left.
Hate to rain on your parade but "Replace shifter bushings" is not "little stuff!" It can be a real PITA--but well worth the effort.
Thanks for the driver side clarification. Through all of the posts I've read, some people give the wrong side and THAT got me confused.
If you read enough conflicting information, the truth can become hazy sometimes.
I refer to the shifter bushings as "little stuff" not from a repair difficulty perspective, but from a larger "severity of issue" perspective.
The fact that I have a completely drivable vehicle that has an inconvenient amount of play in the shifter to me is "little stuff".
Do you have any advice for troubleshooting vacuum leak?
If i fire up a cigar, can I blow it into the PCV valve without breaking stuff?
Or can I spray soapy bubbles onto the hoses with the engine running without breaking stuff?
Gonna do the fuel filter too. Hopefully that will help to improve my MPG's from 10-12(!) . No CEL, no codes.
Cool, thanks for the reply.
Yes, I have spent many hours reading nearly every article
I could find on shifter linkages - both on this board and the internet abroad.
But like I said, the result was I was left with more questions than I had before I started.
Because of the variation in the parts, and the fact that everyone else seems confused about it as well (including a few Subaru mechanics I've spoken with) led me to this post.
I really do try to be self-sufficient.
But thanks for taking the time to reply.
I didn't realize I could see the stupid linkage without tearing it all apart though, so that's a huge help all by itself.
I ended up finding the linkage nearby in NJ yesterday, but I can return it if mine is okay.. Here's hoping. These parts aren't cheap!
Hopefully the weather will be as nice as it supposed to be. It didn't get above 40 today, and at that temp my fingers start to get swollen from the cold.
I'd give my left nut for a heated garage to work in... Working on the street is cold and stressful
Thanks again. I'll post here tomorrow if I get myself into trouble
The more I read about the shifter bushing/linkage replacement
job, the more confused I get.
There seems to be a number of versions depending on model/Mfg. date.
My car is a "bump roof" '96 Legacy Outback Wagon (B11, i belive) with 2.2l and 196k.
The Mfg. Date is 11/95, as per the door jam Subaru badge.
As mentioned in the previous post, I purchased 5 bushings.
Here's the parts diagram I got from the Subaru dealership in Queens.
I bought bushings 4x Part# 35035AA030, and 1x #35035KA010
(circled on the diagram).
I also got a "cable return spring" though some sources say that my
model doesn't HAVE a spring... I mentioned this to the subaru parts guy
and he shrugged and said "you won't need it". It was $2 and i figured what the
hell.
I believe I may also need to replace the linkage; is that correct?
The guy at the Subaru parts department was pretty insistant that
I wouldn't need to replace the linkage, rather I just needed new
bushings. But after seeing photos in this thread http://www.ultimatesubaru.org/forum/showthread.php?t=113480&highlight=shifter+bushings&page=2
(of a nearly identical model, year, and mileage) and his GNARLY looking linkage
The shifter is SO sloppy my wife has a very difficult time driving the car,
which we can't have. Finding third gear is nearly impossible for her she drives around town in 2nd LOL.
I really, really don't want to have to do this job more than once.
As it is now I work late at night; I'm on the street in Brooklyn, NY and
i'm paranoid somebody is gonna hit my car while I'm under it.
So, four questions.
1) Should I replace my linkage, along with the bushings I bought?
2) What is the correct part number? (My sheet designates the linkage as (35046*B.....)
35047AC030
That's what I'm lead to belive based upon the diagram supplied by Subaru.
I called a different Sub dealer in brooklyn with a linkage part number 35047AC010
and she immediately said I was wrong and gave me a "different" part number
35047AC030.
3) Do I also need bushings "35035F" (cirled blue on diagram), or are they included with the linkage?
4) Should I pickup any other parts/bushings/nuts/bolts etc when I go to Subaru this am?
The official Subaru of America parts page doesn't even LIST the linkage;
when I plug in the part number it warns me that 'this part may not fit your vehicle'
THANKS guys. This forum has saved me $100s of dollars already. Probably closer to $1000s.
I LOVE my new (to me) Subaru <3 and I'm having a blast learning about it.
I've been daydrearming of walking away from the IT business and going to Mechanic's
school.
Hey all,
The old '96 Legacy Outback Wagon is shaping up nicely.
I've finally conquered the exhaust leak(s) by installing
new gaskets between all the pipes and cats.
pic.twitter.com/QYzM2VIz - harvested exhaust gaskets!
Next up is the shifter bushings*.
I also caved and bought new exhaust bolts/springs/nuts
while I was there, as the Ford exhaust manifold bolts/springs
I bought at Autozone didn't fit
Anyway, here's my question:
Since the car's steering is totally fine, and from
what I can see by peering into the boot, the tie rod is cool.
How do I know it needs to be replaced?
But if I need to pull it off to replace the boot,
i might as well replace it if it needs to be swapped.
One thread I've been reading :
http://www.subaruoutback.org/forums/111-gen-1-1995-1999/23316-replacing-cv-boots-outback.html
Here's a photo of the small tear in my boot.
pic.twitter.com/AvCgJYAL
Sorry for poor quality.
I do know to mark the tie rod threads before removal (think i'll use spray paint) to avoid needing front end alignment. Surprisingly the alignment on the old girl is cool.
I've been hitting all related bolts with penetrating oil about every night for a few nights now.
Is the driver's side the left or right side??? I've seen both around the 'web, just wanted
an official definition.
Other than that, I have recently developed a rough idle issue under zero load.
suspiscous of a vacuum leak. I cleaned the PCV valve (wanted to replace
but the one dude gave me at Autozone doesn't fit) intake/throttle plate the other night
and although i was conscious of the vacuum hoses, it definetely idles rough right now.
For finding the vacuum leak:
Can i just use a bit of soapy water in a spray bottle?
I read that you should attach your air hose to the PCV valve and BLOW air into the system,
then squirt soapy water.
I don't have an air hose, or any hose that really fits (i could use my shopvac
exhaust to blow).
Or can i just spray while the car is running.
I still need to do the timing belt/water pump/thermostat/coolant flush
so i'm not gonna go nuts troubleshooting the idle issue until then.
Should I just replace all of the vacuum system hoses?
My gas mileage is TERRIBLE, getting about 10-12mpg. Hoping the exhaust
leaks were contributing.
Bought a cool OBDII reader; no trouble codes from the engine.
Any tips/thoughts on poor mileage?
Next up for little stuff:
-Adjust hill holder (it sticks). Surprisingly the front breaks seem fine!
-Replace shifter bushings
-Rear brakes (front ones are fine! i was surprised how much meat was left).
*I've purchased my bushings OEM from Subaru; apparently this model just needs 4 little bushings replaced.
I think i have to remove a rivet that holds the linkage assembly together,
replace the bushings and then re-assemble.
I had a hell of a time figuring out WHAT kind of linkage is in my car,
but dude at the Subaru parts department in LIC helped me. Cross fingers.
Gonna tackle that either tomorrow or over the weekend.
I seized the rear diff in my tacoma within 3k miles of putting Mobil 1 Synthetic in it. Let it cool off and it made it the rest of the way to my destination. Changed the Mobil 1 out (still full to the top, just filled with metal particles) and put cheapo coastal in. Drove it a thousand miles to california, changed with coastal again, and drove it a thousand miles back.
So thats 2k miles and counting on a trashed diff with coastal in it, and 3k miles from a perfectly good diff to a trashed one with Mobil 1 synth.
I've got a pretty high opinion of Coastal Crap right now.
Speaking of which GD, are you still in the bearings industry? I need carrier bearings for said smoked diff and the only ones I can find are dealer only $45 apiece.
Awesome.
This has been highly informative everybody, I can't thank you all enough for your time.
And I'm feeling confident about my "coastal crap" too!
So confident I drained/replaced my rear diff lube with the Coastal as well.
I think i will bring a jug to the LongIslandCity Subaru dlr and get it there next time.
She doesn't like to shift to 2nd gear until it's totally warmed up.
It doesn't bother me, i baby it anyway. Gears don't grind at all it just feels stiff, you know?0
Perhaps lighter 75w90 next time, eh? (that's lighter right?
I wouldn't change it unless I experienced bad shifting.
Many folks use a 'cocktail' of 3 oils over at NASIOC with good results.
Wow, is that right?
I got all worked up like an idiot!
This is great news.
Lucky Texan, do you have a preferred brand/viscosity gear oil?
Hey gang,
Here's a two pronged bone-headed issue.
Car - 1996 Subaru Legacy Outback wagon. ~196k, on it's third clutch (i bought this car 1 week ago).
Long story short, a friend of mine was "helping" me work
on my new (to me) car last night.
He changed the transaxle oil.
I had a new bottle of Castrol synthetic 75W-90
as a "top off" bottle as well as the 4 bottles
of el-cheapo "Coastal" 80W-90 I bought at autozone last night.
TL/DR:
•Non-gearhead friend used
~2.8 quarts of non-synthetic 80W-90 cheap-o oil
and 1 quart of synthetic 75W-90.
That's what's sitting transmission right now.
Do i need to immediately drain this somewhat expensive
mistake and start over immediately?
If so, what make/model of gear oil would you suggest?
Or, i get away with putting a few miles on this current
setup?
The Castrol (synthetic) page says
"Fully compatible with all conventional and synthetic API GL-5 gear oils."
so there's that.
So I suppose my question REALLY becomes, is it okay that i mixed viscosity?
I don't use the car commute to work. Mostly city driving,….
The REAL kicker: the cheap oil's specs page says
" Limited Slip applications for top-off only." Did
Mr. AutoZone give me the wrong oil in the first place?
All of the numbers like "API GL-5" and "MT-1" are there on the
cheap oil's bottle.
I'm an idiot.
On the plus side, the car changes gears much better now
I'm confident what's in it NOW is better than what WAS in the car.
That ************ came out green and STINKY. ick.
Product pages for both of my oil types....
Cheapo Oil:
Castrol "Syntec" oil:
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82915494&contentId=7036193
The better idea would be to flush the cooling system entirely. Takes about 1.5 gallons for a full drain and refill. It would be a good time to replace the radiator hoses and thermostat as well.
Yup you're right. I'll do that tomorrow when I change the oil.
FWIW the radiator hoses are fresh and rubbery. I have the maint. records and that was changed sometime in 8/10. The thermostat as well.
Definitely gonna do the flush though.
Found a new issue while poking around for my oil leak,
driver front strut "Dust Cover" has a hole in it. A rubber boot looks kinda like a CV boot.
It looks pretty fresh actually. Very possible I did it today, as this car wasn't driven really in the last year (except to change street parking spots).
Can i just get a new "Dust Cover" and slap it on there? Should i not worry?
OK Folks, we got the car!
She was down 2 quarts of oil and is already leaking like a stuck pig. The engine SOUNDS way better now, so that's a bit of a relief.
Put air in the tires, now i just need to give it a good wash/vacuum/detail! TOmorrow.
I have a feeling that's why there wasn't an oil slick underneath; she was outta oil Hoping its just the oil pan gasket, we shall see.
Questions: The owner's manual is vague on coolant level. I can see about an inco of coolant in the overflow reservoir when the car is running for a bit.
Should i simply buy a bottle of coolant and fill to the "full" line? Do i need a premix for that?
Hey Miles,
I drove my mother's old 92 Legacy Wagon here and there.
She sold it to a friend of mine for $600 in ~2003; that car is still on the road, with original clutch, with over 300k on it.
My favorite car i've ever owned (i've owned some stinkers) was a '98 Impreza hatchback. 2.5L, manual. Not a lot of extras; didn't even have cruise control. But god I loved that car. Wish i still had it!
I was hoping the owners of my soon-to-be-owned '96 Outback would receive the duplicate title in the mail today, but alas, no such luck. And with Monday being a holiday I won't be able to get it on the road until TUESDAY at the earliest!
I feel like a little kid on Christmas eve. Haven't owned a car since my '98 Impreza, which i gave to my folks when I moved to NYC in '04.
I've been a member for about 10 days, but in that time I was convinced and inspired to buy a '96 Outback wagon that was for sale in my neighborhood.
Huge shout outs to these boys for their guidance and opinions.
porcupine73
johnceggleston
Fairtax4me
Red92
Olnick
themoneypit
Blue Whale
Ricearu
Thanks to them, I'm back in a Subaru! I haven't owned a car since moving to NYC from Madison, WI in '04.
I surrendered my beloved '98 Impreza hatchback to my mother and have ridden NYC metro since.
Luckily, my wife finally agreed to go for a car. So I gotta make this one fly so she doesn't regret that choice!
My "new" used Subaru needs some love as the previous owners were on top of maintenance, but not mechanically sensitive if that makes sense. The Ol' girl is gonna shine and fly. That's why i'm here.
I'm gonna start small with a good wash, oil change/plugs, then move into valve cover gasket land, shifter bushing replacement, and beyond.
This is a wonderful resource and I look forward to speaking with everybody.
Here's my new ride. Sorry its a bad night shot, i'll post new ones soon.
Anybody need a Sears car top carrier? It's about 20cu/ft.
Here's my first thread, where idiot me was convinced it didn't have a blown HG:
http://www.ultimatesubaru.org/forum/showthread.php?t=130197
Thanks, everybody! I feel welcome here already. What a gerat community.
Anybody in Brooklyn? let's get a beer
Whoa..... nuh uhhh. No way I'd go for that. No Title, No Cash, period. That sounds EXTREMELY SKETCHY to me. Why does he just have a Picture of the title?
Timing belt kit w/ water pump and oils seals. http://www.ebay.com/itm/90-97-1-8-2-2L-Subaru-Impreza-Legacy-EJ18-EJ22-Timing-Belt-Kit-AISIN-Water-Pump-/260925109309?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&vxp=mtr&hash=item3cc059343d#ht_2976wt_779
Aisin makes the OE water pumps for just about every Asian car maker.
Nah we good.
I have a photocopy of the original title.
They live 4 blocks away from us and they're super, super cool folks. They just aren't car people is all. He went monday morning and the Duplicate title is on its way.
Anyway, I had my attorney (a client of mine:)) draw up a quick "Bill of Sale" / sales contract.
I paid them half so they could pull the sign and not sell it. I have 30 days to get the title and pay them the rest, otherwise they owe me $400
Alls good.
I just can HARDLY WAIT to get that title!!! I hope it comes today. DMV said by Friday. So I could be driving this puppy Friday if all goes well. I've set aside time to do DMV duty
Update:
I own half of a 96 Legacy Wagon
The owner didn't have his original title (only a photocopy) available, so he has to go to the DMV and get a new one.
So I won't have it in my name for another week or so.
That's ok, that'll give me time to strategize, plan, and budget my repair strategy.
Does anyone need a cargo topper for a Subaru Legacy? It's a Sears X-cargo brand. I believe it's 18-20 cu. ft.
I'll add the model/info/photo once i can take a nice day-time photo, but there's that. I'd be willing to give it to one of y'all if you promise to give it a good home
replace the timing belt, water pump, Idlers, water pump elbow (little rubber hose) and any other original rubber hoses on the car and you should be good to go
oh and check the pcv valve, and change the valve cover gaskets. I would buy it. I could easily double my money on it :cool:
Question:
Regarding the water pump and PCV valve, should i go "original Subaru parts" ?
Got a favorite online/aftermarket shop for this kinda stuff?
Already asked/answered, I'll go 3rd party with the gaskets
Porcupine73 - Wow i'll have to file this for educational purposes
Question about NY title transfer (off topic of my initial thread, but i feel related to my larger theme of buying a used car)
It says on this form http://www.dmv.ny.gov/forms/dtf802.pdf that I need to fill out the DTF-802 "statement of transaction" form (reporting sale for sales tax purposes....) that
"The motor vehicle is sold below fair market value to a person other than a spouse, parent, child, stepparent, or stepchild"
Is this car considered under-valued?
In my case, this vehicle "blue books" at ~2200, yet i'll be paying $800.
(we'll list know/agreed upon maintenance issues either on back of title or on http://www.dmv.ny.gov/forms/mv103.pdf ....
I'd rather not submit a tax form if i can help it
I realize I'll have to pay sales tax when I register it at the DMV, which i believe is 8.5%?
Gonna REALLY press my luck, mention the "oil leak/how dirty it is" and try to get them to eat the 8.5% off the sale price of $800. HARDBALL BABY
This is WAY more complex than it needs to be. Still, lots of not-so-smart folks buy/sell cars privately all the time, so i figure i'm at least half way better !
Bonus: Anyone have a NYC metro area DMV recommendation? Went to Coney Island by mistake to renew my DL a few years ago. Never again....
Update:
got the money together. got the wife onboard (finally) and my dad is even half-way sold on it!
The owners are cool, they're pretty much holding it for me on a verbal agreement/handshake. Its uplifting that a man can still buy a car in this country with a handshake.
I hope to pick it up tomorrow.
First task: become an ultimatesubaru.org donor.
CLEAN the beast. It's filthy, inside and out.
I'll post before and after pics if anyone wants to see them. It'll be like a celebrity makeover man. Woot. This includes oil change, spark plugs/wires/cap/rotor, and research coolant flush. Yay or nay? How 'bout transmission and differential fluid?
Second Task: Gotta get the NY state inspection. So, sus-out the exhaust leak and patch/fill/fix/hire it done. Luckily, there are LOTS of "not chain" repair joints in Brooklyn NY - tire shops, cut/bend/weld exhaust, you name it.
Third Task: For my wife's sake (and confidence), replace the shifter bushings.
This seems to be the authoratative guide on this issue, for a '97. Does it apply to the '96? From what I gather the part numbers are the same.
From there, I'll try to wait for warmer weather for the gasket party.
It's February and I don't have a garage. Also, i don't commute with a car.
THANKS THANKS THANKS
Hope everyone's enjoying their weekends!
Yup,
crunching the numbers but aiming to buy this sucker tomorrow.
They still have it.
If i can't swing it for whatever stupid reason I'll absolutely pass their info along. Like I said, they're great folks.
From those pictures, the fluid looks like engine oil. It may not be the only thing, but I would bet on the valve cover gaskets being responsible for a lot of this mess.
Even the slimy sort of green stuff? Could that be something other than coolant or oil, IE transmission fluid, or axle grease or something?
I wish i had better photos. I'll try to get that done tomorrow if you think that'd help.
Would it be wise for me to do something like a coolant "block test" prior to purchase? Make sure there's no combustion gas in the coolant?
if it IS a leaky coolant hose, are there any consistent culprits to look at first?
Valve cover gasket job seems totally doable. So I'd start there, clean the engine, and see what happens. I think i'll replace the front exhaust pipe gaskets at the same time, and try to locate + patch the exhaust leak.
From what I gather replacing water pump in these pretty much requires the engine to be pulled, does that sound right?
If it is a cooling system hose or gasket or whatever, that seems easy enough. Those parts are in-expensive and the jobs seem possible for me.
Consensus on this forum for HG replacement seems to be OEM part, is does that logic apply to valve cover gaskets as well? Should i always stick with genuine Subaru parts otherwise?
I believe my exhaust gasket part number is H4000-113834. Found them Online for $12, can't beat that. I'd get a few to have on hand.
Lastly, would a compression tester give me any clues about possible blown HG?
After the gasket job, would you suggest I change the oil with synthetic?
Guys I can't thank you enough. I'm leaning toward this car instead of my sister's old Civic simply because this forum is amazing. What a fantastic resource, I'll definitely become a donor if I buy this car.
Forgot to add-
Sorry if I'm jumbling any terminology here.
I've been a "retired" car nut since I moved to NYC from Madison in 04 (when i surrendered my beloved '08 Impreza hatch). So I'm getting back into the flow.
I have a fair amount of tools, but no engine hoist. There is a garage behind my apartment building that the super uses for his car/bike repair business; I'm certain I could gain access to it for at least temporary repairs.
We didn't drive it for long yesterday but like i said it felt totally solid. No overheating. Idled a bit rough but I feel like that's a simple adjustment.
And the exhaust leak doesn't really frighten me, as I think its a flange/gasket. A cheap fix as others have pointed out.
Wow this really is a great community, thanks for your time so for.
To answer earlier questions,
Yup the bluebook on this car is $~2200, so I figure if I have to spend $1000 on top of the $800 purchase price for maintenance we're fine with it.
My only worry is that I buy a car that is going to suffer catastrophic failure with warning signs on display.
Red92 - thanks for digging out those photos for me. Sorry for the poor quality, did the best I could at night (and photoshop to touch them up as much as possible).
I love Subarus. I just wish I had a better/secure garage space in which i could pull the engine on this car and make it a project. I would absolutely love it.
What would you guys do?
My wife and I are considering purchasing a '96 Subaru Legacy Outback 2.2L wagon in my area.
It's $800, 195k miles on it.
I've previously owned a 98 Impreza hatchback, and a 92 Legacy wagon - been around Subarus most of my life (the '92 was my ma's), and have done maintenance chores like oil changes, timing belts, head gaskets, spark plugs, that sort of thing.
So, the details on this old wagon….
Carfax is clean. No accidents. And it shows very regular maintenance, oil changes, transmission fluid, timing belts every ~80k, etc. Current owner bought the car at 35k (lease vehicle). He showed me receipts from a local mechanic, new clutch 2 years ago, rear drum brake repaired. Totally regular maintenance, oil changes, and timing belts every ~80k miles (last one was at 168k).
It's NYC and he doesn't drive it much. Less than 2k miles/year since 2008.
The biggest outstanding "known" issue is leaky exhaust, in the front. It SEEMS to be the joint between the "dual" front exhaust pipes and the catalytic converter. I can spot exhaust smoke coming out of that flange It's also possible the front pipes leak where they meet the cylinder heads.. You can smell exhaust in the cabin at idle if you're stationary. But he says it passes NY state inspection/emissions(!) as is. He replaced the muffler/rear pipe a few years ago, but didn't do the front at that time. So I believe most of the exhaust system is fine.
Oddball minor issue, he shifter is TOTALLY LOOSE/floppy even when it's in gear! That's a new one for me. You can move the shifter side to side even when it's in gear. Trouble?
Other than that the transmission/clutch seemed great. (can be hard to get into Reverse but they all do that right?).
Here's the biggie.
While there wasn't an oil slick on the street where it was parked,
the area under the left valve cover seems to have a fair amount of oil coverage (suspension arm, etc). I'm concerned about the oil, and what looks like engine coolant. Blown head gasket?
There is green "coolant" on parts of the frame/other bits south of the left valve cover (!). Here's a good photo:
http://gallery.mac.com/paulievox/100735/IMG_0178&bgcolor=black/
Bit different angle, note the CV boot for orientation.
http://gallery.mac.com/paulievox/100735/IMG_0180&bgcolor=black
Here's the front exhaust pipe coming out of the passenger's side cylinder head. This where the exhaust leak is, I think. Note the green "coolant"
http://gallery.me.com/paulievox/100735/IMG_0172&bgcolor=black
http://gallery.me.com/paulievox/100735/IMG_0174&bgcolor=black
The CV joints seem fine. No knocking. Boots feel good. Engine has plenty of power. Brakes are iffy, likely need replacing (at least the rear drums). Front calipers appear extremely rusted, and the discs looks pretty worn. The ol' EJ22 Has a slight "knock" going on,but they can get Subaru "piston knock" as well correct?
Does this look like a blown head gasket? Would you run away for $800?
I haven't taken it to a mechanic yet, though I don't have a Subaru mechanic in NYC so I'd have to track one down. That's why I'm here.
As mentioned, the owner is super cool, told me who his mechanic is, and invited me to talk with him and see the complete repair history. I am confident that if he KNEW this vehicle had a blown head gasket/other somewhat major issue, he would absolutely tell me. But he's not a gearhead, and doesn't drive it very much. I don't think he's had it in for oil change/service in 8+months, as I said he doesn't put many miles on it these days.
For your consideration:
For ~$500 in transport cost, I can have my sister's old '96 civic coupe. It's mechanically sound, new exhaust, ready to rock. Much more road worthy than this Subie is right now. But it's a 1.6L 4speed. I love Subarus, but I don't have a great space to work on one. The insurance for my wife and I is much cheaper for the Legacy in our area, so that's a consideration.
Would you take the chance on the Legacy? Or get the Honda out here and be done with it?
Thanks if you've made it this far. Like I said, If I move forward I still want to have it get a good "once over' by a mechanic, but I don't have one I trust -- this will be my first car since moving to NYC in '04.
Sloppy shifter questions: Just bushings, or linkage too?
Posted
I found the Pins to be the hard part.
The linkage wasn't bad. Again, PB blaster applied liberally starting a few nights before helps.
I got mine off with a ball joint puller and a ball peen hammer.
If you pull the transmission down, you could certainly get an air hammer in there i'd expect.
