noisy engine on start up
bugite replied to Anwart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the noise goes away in 30 sec. or so my guess is (cam belt tentioner).had 2 like that.
loud ticking noise at first start up- normal?
bugite replied to courtney's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'v had a noise like that in 2 different subs w/ 66k & 80k 2.5s,cured them both new cam belt tentioner.?
The third eye
on my 1980 gl the button on the dash says passing light.I am missing the door but it does operate. I have a complete set up for a different year but the door is smaller
H6 any good?
bugite replied to davidrg2002's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had my 03 beanmobile4 months pulled a light trailer w/a harley on and got 26mpg doing 75-80 using premium gas only once.most of the time I use reg. I don't notice any diff. I think it gets better milage than my 99 impreza 5 speed stick..??
tranny shifting slow
bugite replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe problem is @ 50+mph going from 3rd into drive. may be I wasn't clear. is that the problem you had. thanx for reply
bugite replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe manual instructs how. I'll give it a try .What about not going into drive? it just started acting up I want to catch it early if I can.Thanks for the help.
I have a 98 forester awd 62k, new fluid(cheap stuff) changed it because it smelled burnt,also filter, so i got 6 qts out.It shifts slow from 2nd to 3rd tac.drops slowly from around 3300? to 22000? maby1.5 secounds also it has started to not shift,or delay to drive, it started when very cold now it does it now & then. Any advice? better fluid for sure! band adjustment?
trany growling @ me
bugite replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHAPPY DAY i found the problem.i noticed earlier there was a bent bolt/stud in center of tranny cross member,didn't think too much of it. i said before it ia a repairable,hit rite ft.,hard enough to bend that safty stud in tranny mt.and was up against metal transfering every vibration & sound to cross member on into whole body, i think this one is for the books but not your average case, thanx for your help this is a great sounding board, BUGITE
trany growling @ me
bugite replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis thing makes the same sound @all speeds, i went through each gear 1st speed up, no noise under load, untill it got up to speed & deceleration worse.2nd the same & so on,worse noise @ shifts but i'll check them tomorrow. thanx again
trany growling @ me
bugite replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell here's the skinny(any body still use that term?)changed all fluids, rt ft cv shaft,(felt good but changed it anyway,to be safe).checked drive line. still makes growling noise in all gears as soon as you get up to speed.under load no noise,much worse on deceleration,&during shifts .parked it seens to have a viberation when reved.is it time to look for tranny?whats best thing to do.thanx again
trany growling @ me
bugite replied to bugite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreply here?? automatic AWL i think, its a forester S (98) when I bought it i had been hit on rt ft corner, need lower A frame,fender head lite etc. ?i droped all fluids today trany was a little burnt& a small amount of metal flakes & grafite as to be expected the diff's look good,but a did discover what i think as a lose rt side cv i'm in the prosses of pulling right now.i always thought a cv would make a clicking sound on hard turns?not true? i'll be back in a couple hrs,thanx bugite
trany growling @ me
I'm just getting this repairable on the road,took it for a test ride yesterday & the trany seens to make a lot of growling noise when it shifts & esp.on deceleration also a high pitched whining noise.it seens to be less on excelleration,note:all tires don't match rt ft is33 or 38 dont rember "s but 33 1/2 lf 1/4 & rear match @even 33, please help
flashing forester
I have a 98 forester hit in rt ft corner,I couldn't pass it up.body work is going good but my problem is the flashers come on as soon as I conect the battery.I've checked the wires for shorts in the front,pulled the flashers units under dash,heard the computer box ticking.any one have ideas about this I would sure appreicate the help,thanx
bugite
