Posts posted by BendSuby
Por-15 is not supposed to be exposed to sunlight if I remember correctly. Possibly part of the problem.
Its a 17 MM head on EA81's, can't seem to find the thread size in my Hayes. Maybe pull the bolt and take the remaining one into a hardware store and match it up!
Been watching alot of youtube videos on it. Seems like a very simple process anyone can do at home. Although they are probably professionals as well. Looks very nice on your sedan!
Looks good! Have you heard anything good or bad about the tint from wal-mart?
I would appreciate some pictures, ya!
Would a blow dryer work? And did you do them without and wrinkles or bubbles?
Has anyone ever done their own window tint to avoid paying the 2-300 hundred dollars at a tinting shop? How hard is the process?
Anyone ever made anything molded or something? Something that looks more factory?
Sweet! Thanks!
I have the same problem with one vibrating out, and having trouble with an exhaust leak. 7/16 by 20 or by 14 correct? What do you mean by 2x? Also, did subaru have a gasket between manifold and block from the factory?
If I remember right you have to have it in the right position and slid to the drivers side all the way I believe then pull the passenger side out. Kind of like a tail gate. I believe there are little plastic pieces around the shaft that you have to rotate until they line up as well. Its been a while, I could be wrong. Hope that helps.
Struts
Posted
After searching on here for a while, I haven't found the answer I was looking for. I have a '84 Subaru GL, I was wondering if there is a better option for struts? Is there a strut made with more travel by chance?
