Everything posted by dunk
general Interchangability?!... and o2 sensor conversion..
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks.. dont really want more power.. just want to know if i can get parts from the scrapyerd if necessary:) o2 sensor.. theres no plug/bung/threaded piece for it in the exhaust anywhere... in the u.k. we werent running exclusively on unleaded back in '90.. so no cat converter either!.. leaded was pretty much 99% phased out about 4 years ago... as i say there are wires on the loom that just "end".. looking at manuals i have seen they seem to come from relevant places on the ecu... s'pose i just check the error codes and see if it comes up with o2 sensor?!... wonder if all the u.k. models of this era ran with error codes as standard?!... hmmmnnn...
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXanyone?!...
hello there.. my '90 ej2.2 legacy runs quite well now.. thanks to help from people on here:).. however i have a few more questions... i)im in the u.k. and the car is a 90-91 model.. theres no provision for an 02 sensor on the exhuast.. however the harness "seems" to have some spare black and white wires that look as though they could go to one... would it be possible to retro fit the sensor?... and more importantly.. would it be worth it?!... would it increase/decrease power or drivabilty?! ii)what items can be taken from later legacies/imprezza's to fit earlier models?!.. basically im talking about ej motors... coil amp?, coil pack?, crank sensor? cam sensor? TPS? for example...can i put a manifold, coil pack and TPS from a 96 2.0 legacy on a 90 2.2 legacy?!... thanks for any help...
O2/lambda sensor...
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXinteresting! thanks for the reply skip... didnt think of it like that... still, if the egt sensor is supposed to be in the exhaust.. its not there now? hmmmn.. i know you can buy exhaust for the early legacies over here in "catalytic" and "non catalytic converter" style... will try and do some research... not going to be easy! this is probably the best forum for all round subaru tech stuff.. the ones over here concentrate on car with over 250hp... 90% of the time imprezza's... i dont own an exceedingly expensive imprezza and i dont want expensive mods... (hmmmn yet!..) i just want my car to go! thanks for the help though..
O2/lambda sensor...
me again with more problems:confused: well questions really... cars running fine now after the fuel problem... its a 90/91 2.2 legacy awd auto gx However... it doesnt seem to have an O2/lambda whatever sensor on the exhaust... do all the subarus have this? or are there a few early ones that dont use it... looked briefly at a wiring diagram for the ecu... has alook in the car also, there seems to be some white and black wires wrapped in a grey sheath that *might* be something to do with an O2 sensor but they are not connected to anything... there is no plug/nut/boss welded into the exhaust to take the sensor either.. i am a little confused as the car seems to run fine?!.. am i destroying the car by running it like this?... how do i go about putting the sensor in?..weld a nut onto the exhaust and extend the wires to suit?... does anyone have an accurate wiring diagram that i can check?.. any thoughts or suggestions would be appreciated..
HELP! engine dies under load!:(
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfixed it! seems to be a slightly kinked fuel line and the filter... rerouted the fuel line with a new piece and installed another fuel filter... everythings good now... thanks for your help and suggestions everyone, much appreciated..
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXARRGH! update.. put some more fuel in it.. disconnected the fueline to the injectors etc... put hose on it going into a jar.. turned on the ignition 4-5 times.. can hear the pump going.. barely a dribble if that coming out.. it should shoot across the room, no?! or fill the small jar pretty quick.. if the pumps working properly, and i followed the direction written on the filter to install it the correct way round.. whats happened?.. crap in the bottom of the tank clogging the filter? just a bad filter?... im assuming the filters clogged and will try and replace it tomorrow...more money:( it did work fine and revved fine for about 10 mins... switched off... came back 5 mins later, then all the trouble... again.. arrgh! thanks for all your help so far...
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi put the new filter and pump in... bled the brakes, did a few other non engine things... connected everything back up.. started her up... seemed fine... had one small hiccup, restarted, and then o.k. again... revved it briefly, seemed o.k.... rolled it forward out of the garage to re-park it more "centrally"... tried to reverse and it wont move itself under load.. i.e. exhibiting the problems in my first post.. havent attempted any fixes yet... any other ideas?!... where should id go from here? should i test the filter and/or pump?!... how?.. or just put some new petrol in?!..
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgentlemen... right on the money!! just put a new fuel pump and filter in!!! why is this happening? what should i do next?!... goddamn you guys are good!
90 legacy 2.2... engine starts pretty well... as soon as you put your foot on the gas, it revs to about 15-1700 then tries to die.. after a while it doesnt even try to rev.. keep trying for a few minutes and it wont even start... i left it for a few minutes again and it will now start...but it just repeats the above procedure.. drove it out of the garage now it wont go back in!... its gonna roll down the slope!:-\ Help please!
more questions!..fan in a 91 legacy..
things seem to be going well at the moment.. thanks for all your help so far.. cars running pretty good:) However, dont know what temp the fan should kick in... have run it a bit in cool weather.. and nothings happening... the car hasnt been run for some time... is there anything i can check?... i presume its ECU controlled?... what temp should it start up at?... thanks again..
In a '91 Legacy, where is the sender...
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks guys... Mr 777 whre do you get all these fabulous pictures from?! makes things alot clearer:) BTW i need the small, single wire one;) much appreciated..
for the water temp gauge located on the engine?... i know its 1/8" NPT thread, ive been told its at the back left of the engine.. but i cant see it?!.. anyone got a picture?... do you have to take the inlet manifold off to get at it or something?!... cheers:)
idle problems again :( sorry...
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfound where the hose went... got it reconnected... undid the battery terminal to reset the ecu... fiddled with some other bits and bobs for 30 mins.. connected it all back up... it starts and idles real good now!... much better..thanks for your help everyone..
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXaha!... thanks guys.. will try reconnecting it tonight...
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXupdate!... cleaned the MAF sensor and IAC valve... upon startup it doesnt "bounce" the revs anywhere near as much.. which is nice!.. however it stil cuts off dead after about 5 seconds... i noticed that the 19mm?!.. tube that connects directly to the IAC valve is not hooked up to anything.. its just sucking in air.. could this be the problem that stops the engine idling?!... it should be connected to the air intake, downstream of the MAF sensor yes?!... thanks for all your help so far..
dunk replied to dunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for the replies.. so the big hose with the clips on goes to the iac valve.. the other end is connected to the air inlet duct i presume?!... the tiny hose is the coolant one to the throttlebody yes!?... MAF is plugged in:) BTW before i try to clean the iac.. is this diagram correct?.. http://www.rb5286.pwp.blueyonder.co.uk/Technical/Idle%20Air%20Control%20(IAC)%20Valve%20.htm once ive cleaned it i need to disconnect the ecu for a period of time to reset it, yes?! thanks:)
hello there everyone! i have some questions on a project i aquired recently.. a 91 legacy in a world of hurt!... pcv hoses were all over the place, nearly got them sorted.. im gradually reconnecting the coolant hoses.. where does the one that seems to come off the side of the throttle body go?.. havent got any engine bay pictures to reference to unfortunately:(... now then, theres no water in the cooling system.. but i need to see if it will run.. so after some fiddling with the wiring and replacement of connectors.. all is looking good.. turn it over... it starts!... wont idle though!.. goes up 'n' down between, say, 400 and 1100 rpm about 3 times getting everso slightly smoother.. and then cuts out... if you hold your foot on the gas itll keep going and seem to run o.k... but will die as soon as you let your foot off... and no im not going to run it more than a few seconds because of the no water situation! after reading a few threads on here.. is the IAC my problem?.. run some injector cleaner through the fuel system?.. or is the computer shutting it down cos theres no water in the system?... where is the IAC?! what do i do to clean it?.. you seem like knowledgeable guys.. help!
