Posts posted by Tronkus
Hi Guys:I still working on my car. I need help with some issues...¿Anyone knows if i can swap a dashboard from a subaru GL to my subaru DL?. In first place, the connectors are not the same, but maybe i can do something to fit it?Best regards
...the Third thing is the Fuel injector itself, if your EA82 has the MPFi setup, but if your engine has SPFi...
JesZek, i don't understand that part. ¿what do you mean with MPFI setup? my EA82 engine is SPFIBest Regards
Hi Guys:The fuel pump works excellent, no more problems. But...the engine still work on rough idle... I change hoses, fuel pump, spark plugs, check vacuum hoses, but nothing. One piston doesn't work. I check the spark plug and cable and both works correctly, but if i remove the spark cable nothing changes, the engine still working badI need ideas about what is wrong.Greetings
- 1
Yes, also looks nice to me.
Have you received your New Fuel Pump?
Kind Regards.
Yes, arrived yesterday. Here's some pics:
It's from a Ford Ranger, i think that i need to adapt the pump because the hoses are more big, no?
Best Regards
- 2
I bet you used Green LED lights, isn't it?
Looks Good. Kind Regards.
Hi JesZeK:
No, i just use white led lights, the dashboard numbers are green. Looks nice to me.
Best regards.
- 1
Hi Guys:
Finally this are the results:
Sorry about the quality of the pictures.
I only have to work on the speedometer, doesn't work properly
- 1
All your Answers are Here:
Kind Regards.
Exactly, that thread is my guide. Thank You JeSzeK
- 1
Hi everyone:
I still working on my DL. Today i start to change the ligths from the dashboard:
I only have one problem. As you can see, there are many "holes" without lights, so i don't know if i need to buy more leds light or not...
Best regards,
- 1
No problem, i ask because i build them. http://www.ultimatesubaru.org/forum/topic/148582-anderson-design-fabrication/
So my prices are shipped within the U.S. but if your interested i could work on getting a quote for shipping for you?
Patrick
Sure! Please send me an PM with the cost.
Gorgeous wagon, looks clean!! How much do you think shipping would cost from the states to Chile for the 2" lift kit?
Prwa
Thank you for your comment. I don't know how much would cost the shipping, depends on weight and the shipping method or company.
Best Regards
Hi Guys:
I still working on my car. Unfortunatelly i couldn't find the reroute PCV kit. My car is leaking from on hose of the PCV system. Anyone can help me to find that kit? or sell me that parts?
Best regards,
Guys, finally i found the problem in my car. One piston doesn't work, the spark plugs works fine, but the engine still vibrating. i dont know how to repair that problem. Any ideas?Best regards
Arrived yesterday!!!
- 1
New stereo!!!! Cheap but very functional...
- 1
- 1
Some pictures of the fuel pump:
I didn't found in my city...
It is important to know if your 1989 Subaru DL Wagon,
has the EFi or the Carbureted Engine.
Kind Regards.
Hi JesZek:
It's an 1989 DL SPFI engine.
Greetings
I found this alternative fuel pump, it's ok?
Is noisy?
Greetings
Honestly, if the Fuel Pump is getting bad, it could left you stranded in the Middle of Nowhere, so your only "Cheap" alternative to a Genuine, brand New Subaru Fuel Pump, was already pointed by MilesFox: Use one for a Dual Tank Ford, it also is External and could come from a Junk Yard Car.
Kind Regards.
Edit: I called a previous owner and tell me that the fuel pump installed in my car is from a Peugeot. Which one is the original fuel pump for my car? (number). i found a Bosch alternative, but i need to compare with the original.Greetings -
As MilesFox wrote, the Fuel Pump is outside the Tank and easy to Change, look at it next to the Tank. It also could be Loose and / or having a clogged Fuel Filter issue.
Worth starting by Changing the Fuel Filter...
Those were on Private Messages...
You're Welcome!
JesZek:I change the fuel filter, but the fuel pump it's too expensive!! (at least here). what other alternatives i have?Greetings -
Hi guys:I still trying to repair my car. But i have a problem. The car make a sound constantly like a bee. It's not the engine, because i check the engine and the sound is in the rear and maybe it's the fuel pump...¿it's in the fuel tank?-The engine still vibrating at low rpm...i change the filters, clean the injector, check the vacuum but still happening...any ideas? (Thanks JesZek for the advices)Greetings
- 1
Hi Guys:
I continue with the project (Subaru DL EA82 1800cc). Actually:
-Tyres changed.
-Plugs, wires, filters and breakes are replaced.
-Block re sealed and change the coolant.
Next steps:
-New Painting
-New Interiors
-2" Lift (I can't find nothing in my country)
-Change gearbox.
-Change wheels (13" to 14")
Some pictures:
Greetings from Chile!
- 1
Awesome Job!!!
Hi guys:
Finally i can get my own subaru . Buy a DL '89 in excellent condition. I want to make some changes on him:
-2" Lift
-Change tyres and rims
-New painting
-Etc.
Some pictures:
Greetings from Chile!- 3
GL Dashboard to DL Swap
Posted
Luis
