cpreset
Posts posted by cpreset
lol 85mph it reads corectlyish if need be i just use my gps for a speedo and im only a four speed still
hrm sounds like more of a pain then its worth ill change it if need ie: it breaks
how hard is it to replace the cable \seal
What would cause my speedometer to bounce at low speeds and also around 55-60? the car is a 85 gl hatch
i got one of those in my 85 hatch but its only a 12 led one looks nice
lol I don't think my car has bomb insurance
you can try this for the blue http://www.turtlewax.com/product-detail.aspx?prodid=64
ok just checking good to know that it should be doing this
do you have an 02 sensor then you might have a feedback. well any way the est resort for me was to rebuild the darn thing it is the best option external cleaners dont work you need to get in there and clean the jets
what carb do you the stock or weber?
sory though i posted that guess i diden't its a 85 ea-81 hatch
this is the most ive posted in a while. well when i have the key on and have not started the car there is this erie rapid ticking like a relay rapidly opening and closing near the carb n the motor bay and btw this car is full stock so any ideas im just trying to fix all the stuff on my car while i have cash:D
cant think of an easy and cheap way its either elbow grease or pay someone else to do it. i just washed and waxed my 85 hatch two less doors still alot of work
ok good news it works i pulled that connector off and well it was corroded to hell. so i took some sand paper and cleaned up and started the car got it hot and... the fan kicked on! so i will be replacing the fan soon when i have cash to spend on it but as of right now it works and that's all i need thanks for the prompt help guys:D
ok i tested my fan i just hot wired it to the batt and it worked just fine im a little confused on how to disconnect the sensor and were it is. is it on the back right above what looks to be a plug or some were else also i omed the rad ground wire and it had came out good
ok im going to say this i think its my fan i cant hear it run anymore it used to sound like it was grinding rocks so i think its not but my dad asked if it could be a coolant sensor and i don't know if there is. so my question is is there a coolant temp sensor if so how do i check to see if its working right
well i got my carb working forgot to readjust the idel fuel air mix but my car has started to overheat im think its my rad fan ill be working on that now ill star a new thread for that after some searching if need be
ya its a ea-81 I don't think its the float i just cleaned all of that
ok i just re-built my hibachi on my 85 gl hatch and its fiered right up i was happy went and locked up the house to go for a drive and i pull out of drive and i let off the gas check that its idling it was. then i give it gas to take off and it dies now it wont start. what should i do? a little more info i look i got fuel in the float bowl and im getting spark so that's not the issue im pretty shur i have no vac leeks. any help would be appreciated also need this up and running by tomorrow so please help me
Hi i was wondering if anyone on here has experience with b5 bodied vw passats
It's one of the nissan cars that can be used, I just don't know which one it is.
Its a 200sx heres the write up
i don't have part numbers but it was a set that you have to cut yourself i got from cb performance that's a vw bug performance site here is the link http://www.cbperformance.com/catalog.asp?ProductID=1474
they are a pain in the finger to get the boots on the cable if you do it i suggest a lot of soapy water
The last photo made me laugh with the Facebook photo tacking place in the background
Good place to buy a stock carb?
Posted
have you though about going to a pick and pull and yanking one of another subi the rebuilding it yourself?
