Everything posted by Maleki777
So I took it for a ride a few miles up and down the highway, no more p0100. However I still need to replace my front o2 sensor. I'm getting a high voltage reading from the code scanner, 1.275. Think that will smoke my new/used MAFS? Or should I be good till friday when I get paid? Also ever hear of "MEAS" readimg on those scanners referring to voltage of o2, 0.090make any sense?
Just switched em' the one that came out was assembled in the USA installed one says made in Japan, wondering if old one is aftermerket? Also that "fluff" fell off, should I cover it with electrical tape? Should I worry about it, is gunna screw stuff up? Battery disconnected clearing codes, gunna go for ride soon and check for codes at advanced. Thanks alot dude, tell me what ya' think about that fluff if you could.
EJ22E phase 1 symptoms bucking, stalling, no fuel "feel" same as "95 legacy bogging out" thread. Fairtax,nipper,ricearu,olnick you guys help me out, I'm sure you remember. So I got a p0100 MAFS sensor OR circuit malfuntion. Got a MAF frim the boneyard but what if its the circuit? Where is this circuit? Same thing with my p0141 o2 heater circuit malfunction wheres the circuit? Also got MAF connector with about a foot of wire, one has bare wire coming out around like a double insulation prong number 4, any ideas?
95 Legacy EJ22E 5 speed with cruise. While the car is running not in gear clutch NOT pressed in just sitting there. I hear a sound like metal rubbing together. Push the clutch in and it goes away. I think it's the fly wheel ans pressure plate just barlt touching, do you agree? If so can I simply adjust the clutch and cure this? Been like this since I got the car. Also the squiking from the fork where the cable hooks up, whats that? Seems to be having an affext on peformance. Not slipping, also grabs about 3/4 up. THANK YOU SO MUCH FOR ALL THE HELP SO FAR!!!
Ignition.
Maleki777 replied to Maleki777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks Fairtax, you've been a great help!! Yeh seems like it was a one time fluke thing, floor mat got in the way maybe. I have had numerous times,when I didn't push the petal far enough. I'm looking in my haynes manuel now, seems simple enough, if needs be which I'm not going to worry about now, worst case I bypass it, THANKS AGAIN!!! -
Hi, 95 Legacy 5 speed. Last week after getting gas I turned the key and I heard from the steering column a electric screeching sound, not real loud. Didn't start, turn key back then fired it right up. Few details then a few questions. The key is a copy, ignition is original key matches door. Clutch safty switch working fine. Original key could be a copy, looking at it now, all metal no plastic top. So has anyone ever squirted that real fine graphite powder in theres? Did it work? Can you change ingition without removing wheel? Yes its got an airbag. No rush just thinking of the furture, THANK YOU.
I used the spray one today. First got it for the IAC, jumpy idle. Went like 6 ounces through vacuum line off air duct into IAC, I figured I would go the other six ounces through brake booster to evenly distribute it got a little left. Idles better, no up and down. However I didn't think of this at the time, it came with a real long insert tube with a plastic 180 degree braket I belive so you can put into the throttle body and put the air duct on to keep in running, I could be wrong. I tell ya it's good stuff for finding exhaust leaks!!! Another thing on the list for me!!!!
Hi, I was wondering if you could answer two question, I noticed your a moderater of the site. First why can't I add attachments? Noth that I want to right now just curious? Also I was In the boneyard getting a few things while checking engine codes to make sure I was getting the right part found a little outback sport coupe engine code was "ej18e" never heard of it, have you?
Wow you guys know your stuff!!! Ricearo that's the exact number 33yr sub tech said computer thinks it's 40 below!!! I have another question, a new thread may ne neccasary, it is possible to clean a o2 sensor? Gettin mixed amswers all over the net. Amd have any of you done it? Any success? MAF cleaner, brake cleaner, electrical point cleaner, etx?
To whom it may concern, in conclusion I drove the subaru from Webster MA. CONN. Boarder to Haverhill MA. At the N.H. Boarder 150 miles round trip and the EJ22E never missed a beat!!! I think it's fair to say the subaru tech nailed it with ETC Sensor. While I was up there went to Brandy Brow junk yard probaly oone of the best in all of New England and grabbed a TPS, Igniter, and that stupid brack that holds the windshield washer motor in place, my cracked and wiper flop over windshield. Anyway grabbed the two for backups to cheap not to. So thank yo u all for your help, o2 sensors next on list, couldn't get at any bone yard!!! Thanks again:headbang:
So this morning fired it up and it died in five seconds, and would'nt start fed up I towed it to the sub dealer. Bad ETC Sensor, tech said wont run cause ECM cant tell wwhat fuel/air mix. Funny I checked for spark and had none they never said anything about it. Also tech said cam/crank sensor was recalled in the 95, so if urs are brown no good. My cam was black and crank was brown e gave me a free crankshaft sensor just threw it in. aside from that I'm gunna get new o2 sensors when I have more money and my o2 codes have cleared for now. What else should I be investing in? EGR, TPS, IAC? Running good, still a up and down idle for a few seconds before it levels out. Anymore ideas, its all about preventive matience now!!!
So I sprayed all the vacuum lines with brake clean and no increase in RPM's. Also pulled code from haynes manuel p0141 " downstrem o2 sensor heater circuit malfunction" & p0130 "upstream o2 sensor or circuit malfunction" also could emphasize "drive cycle" do you mean starting car stopping and starting again? Anyway I'm going to hit the bone yard and get some sensors clean em' with MAFS cleaner double check ALL my connections and grounds, see if that helps.
First let me say thank you for your responces, I'm very grateful to have access to all your brains!!! Ok, stock air box snorkel etc. yes, MAFS cleaned, NO CHECK ENGINE LIGHT, however I just went to advanced auto and used the.computer for the hell of it and got two codes, upstream and downstream o2.sensors, does that make sense considering no CEL and yr make etc.? Here's the codes p0130 & p014, also a while back took spray bottle with soapy water no vacum leaks and PVC clicking the way it's suppose to. I'm gunna get some o2 sensors from the bone yard see what happens. If you giys are not to bisy tell me what ya think about codes with no CEL THANK YOU AGAIN
Hi everyone, I have a 95 Legacy phase one noninterference single overhead cam hydrolic lifters ej22e. When traveling at 75-80 mph it will sputter for a second or two. The systom will remain for many miles off and on. Then at lower speeds amd rpms it will buck and figjt for rpms and "cough" or "hiccup" that bass kind of sound for four or five seconds then vrooom of it goes. It is not a wet or cold weatjer thing very spuratic. What i've done: coil, wires from subaru, plugs, MAS cleaner, different gas station with additive. No problem today but like I said comes and goes. Any help would be apprecited
