DreamBeavr
Everything posted by DreamBeavr
  1. ....the belts on the rear tire started to separate. Apparently not a front end situation at all. Could have knocked me over with a feather. The only place I didn't really pay any mind to. And why I got so much wobble in the front end I guess I can't figure. Replaced the tire, no more wobble! Thanks for all your suggestions.
  2. "warped disc"? You mean disc pad or rotor? I can see a rotor but, not a warped pad!
  3. Does not get worse as we acclerate. It is worse at 0-20, then isn't quite as noticeable. BTW it is a '91 Legacy...AWD. Thanks for the idea on tire...one thing hadn't thought of. Experienced that one before. Running BF Good's at this time. Usually a pretty dependable tire. Thanks
  4. Looking to fix a front end wobble that is more pronounced at low speeds but, still noticeable at higher speeds 40+. Feels like a side to side movement, not one that you could associate to flat tire or alignment. Maybe a tie rod problem? I noticed a rubber boot that is split. Not the CV joint but, not sure on what it is. Tie rod?
