mountainbikeak
Posts posted by mountainbikeak
Thanks for the replies! I did grab oem thermostat and radiator cap, I've heard others didn't work well!
After a few hours my compression went from 16psi to 4psi, obviously I have a leak somewhere in the cooling system. Also, after degreasing everything a couple days ago I finally got a look at the seals... Passenger side looks good, drivers side seems to be leaking from the exhaust manifold, didn't look like it was residual oil from something else, what would cause this? Tomorrow I'll change out coolant and install new thermostat and see how things go! Also with the block tester, would I get an accurate test from the overfill reservoir? not super familiar how to post pics to this forum, check out this to see a couple pics of the area in question. Thanks again! -
Thanks for the reply... Fans come on just fine and it seems to get good circulation now, not sure about head gaskets, I sent the original owner a note, just waiting to hear back. The timing belt was replaced last year and I don't think they put any conditioner in the coolant, so I added some a few months later after realizing it didn't have any (hopefully not to late). It doesn't overheat on just normal loads other then the one time the radiator hoses were compressed. I'll look into the radiator being clogged.
Retested the oil for water with negative results, again by heating it up, and the psi is holding on the coolant pressure test. Should I check anything else, spark plugs etc.? Thanks again!
I know the head gasket topic is huge on here, I just can't seem to find exactly what I need so maybe someone can help me out here!
I have a 2002 outback 2.5 that I first notices overheating (not redline) when the outside temps where higher then normal and while pulling a raft, just figured the circumstances would cause this. Didn't notice any substantial rise in the temp gauge while just cruising normal until the next time i drove under load, again not red line and I turned the heat on etc. Then one day the thing wanted to overheat at low speeds,not high speeds, seemed like it wasn't getting coolant, checked it out and all the coolant flowed into the overflow and the radiator hoses were smashed (sucked in). I replaced the radiator cap, bought a new thermostat just in case (didn't install it) before a big trip with raft and gear. It wanted to heat up on big climbs but everything was normal while driving in normal conditions. (I was loaded, 2 adults, 2 dogs, gear for 5 days on the river), Coolant cycled back through ok. I have't noticed the usual signs of a blown head gasket as the heater always would blow hot air, no bubbles in overflow/radiator a small discoloration in the coolant but that could be from the conditioner, no other spikes in temp. However, after the trip i checked the oil and it seemed really high and sort of frothy and I was getting some oil leaking on the exhaust after long hauls (looked to be leaking towards the rear), I added oil before our trip but was pretty certain I didn't overflow I also didn't notice anything near the fill cap or any sort of white residue. since then a couple days ago I changed the oil/filter and have been monitoring things and haven't noticed a change in oil level but it almost looks like a hint of green coolant, can't really smell it I did a crude test dripping oil from the dip stick over a heated soda can and didn't get any signs of water, I have a coolant compression test on now and it hasn't moved in a couple hours and I did a block/gasket leak test that came up negative. (the test was super difficult because I couldn't keep the coolant low enough and it wanted to get sucked into the test tube after a minute or so) I did try through the overflow not knowing how accurate it would be from there with negative results.
At this point I'm looking for advice on how to confirm if this is actually a HG leak or something else and how can i check for sure if coolant is in the oil and not my imagination? Couple things I've done in the past few weeks are: New valve cover gaskets, pcv valve (subaru), radiator cap (subaru), fuel filter, air filter, spark wire and new spark plugs.
Sorry its so long, trying to streamline this to make it easier on folks trying to help. Thanks a ton,this forum has saved me on a few other issues!
josh
Thanks guys... I did get the thermostat from the dealer and just wanted to make sure as I also noticed it was round. Thanks again.
I realized I didn't make my question too clear. Got the spring down, does it matter which way the loose toggle thing sits?
Pretty lame I know, I searched for something here with no luck. Which way does this thing go in or does it mater? Thanks in advance.
I've got a 91 Loyale that is acting up a bit... just wanted to check the timing on it but have a quick question that I hope will clarify a couple things for me.
I know the timing should be set at 20 degrees so I should rotate the distributer so the 20 matches up to the obvious "point" in the viewing window (under timing light of course)... Sorry for the lame question. WHile under the hood just before dark it looked like I'm set near 0 degrees. Likely a reason for poor gas mileage, suspicious running habits while driving? Thanks in Advance!
Also just to clarify, which is my number one spark plug? Thanks again
thanks for the help... Got things cleaned out, thermo changed and the heat is working great! Lost the gloves and extra warm hat on the way back from the shop.
Just to be sure... the two hoses that run parallel to each other going into the dash area of the car is what I'm looking for? Looks like the one on the right while looking from front to back is going into the water pump. Sorry not the most knowledgeable on this stuff, you guys really are killer for the help!
I'm going to change my thermostat this evening, figured I would go ahead and flush the system while I was at it. Any suggestions for this, will a flush kit work on a 91 loyale? Can I just drain, add water and drain until clean? Any advice would be greatly appreciated, thanks.
- 1
Thanks guys... I'm going to pick one up tomorrow just in time for some warmer weather i'm sure.
Coolant is full, could use a flush if sure... The temp gauge will read nothing most of the time, every now and again it will pop up just a bit maybe 1/8" or so. When it's up just a bit then I get some heat. Under normal conditions it will come up for just a bit, but under stress like climbing it will read for the entire climb but still only 1/8" reading.
I found a few posts on here that almost answered my question but not quite, hoping you guys can give me a hand.
I've got a 91' Loyale with a manual tranny. I had this car parked for 3 years or so and started driving it again last winter. I noticed on a cold day the heat wasn't working like it use too. It was the end of winter so didn't pay much attention to it and I'm gone for most of the summer's. Now it's winter and cold again and i've paid more attention when I have heat and not. Always have just a bit (lots of air coming out vents) but when the engine temp goes up (which is usually just above the first line) then I get some good heat which is about 3 percent of the time.
Could this be a sticky thermostat messing with me?
Any help would be nice. Thanks in advance!
I have a 91 legacy that when I accelerate the shifter rattles. If I move the handle over just a bit it stops. Is a seal, rubber washer etc. possibly warm out? Any help would be much appreciated as the noise is getting old!
Thanks
I'm looking at buying a 91 legacy with 220000 miles from a friend. While test driving it I noticed when I would shift it up or down in to gear at a certain time just before engaging and disengaging the car tends to jerk. YOu can hold it right in place and the car just "surges". My friend has kept a great maintanence log and the clutch was replaced around 60000 miles ago or less. Could the clutch cable just need to be adjusted? The cluth doesn't seem to slip. Any help would be greatly appreciated, she is going to vacation tomorrow and I would like to buy before she leaves. THanks prior.
Josh
Right on guys, thanks for the info... I thought Deep inside it might be that, dang. I'll check it out tonight and turn them/it 180. Thanks again
josh
I just replaced both front half shafts, most everything went ok, but now I can't get the pins in near the transmission. From what I understand the shaft can only go on one way and when Installing them I checked and made sure I aligned the valley of the spindle on the shaft to the ridge on the other end, seems just a bit off, enough where I can get about half of a drift through. Any help would be greatly appreciated need some wheels for work tomorrow.
Thanks ahead of time. josh
I think when I get back from guiding this summer I'll retap to larger size, this time I just got a bigger metal screw and forced it in, between that and permenant loctite i should be sitting good for awhile. Otherwise suby is running stronger than It ever has. Thanks everyone for the time!!! Josh
Some of you may remember when My damned bolt that holds my rotor onto my distibutor came loose, well it happened again, and I should have known. So yeah I got a larger screw and forced it in, should work now. I did get my filter changed which besided the 23 bones was a good thing.. thanks for all the help Josh
yeah I'll give it a try tomorrow sometime, really strang how I got one thing fixed and then something totally random and out of nowhere come along... crazy, I did at one point have some very sparatic idle then the engine light came on and read a bad tps, could this also cause what my symptoms are?
Ok after a successfull wheel bearing transfer and almost 50 mile drive home I actually thought to myself, "This thing is really running good". Well that didn't last long. On my way to work this morning I right away noticed some hesitation but didn't think much of it. A couple miles later I noticed that everytime I accelerated the car it would start out choppy like it was missing or not getting fuel then level out a bit with more rpms and then when I get ready to "cruise" hold the rpms pretty low it really hesitates, the car shakes back a forth and has not guts. I also noticed it would do the same thing while parked in neutral at about 2500 it cuts out and hesitates. I did fill up with fuel before the trip out yesterday could this be bad fuel, fuel injectors? Some insight would be very helpfull. 91' loyale 4wd manual. 185,000 miles
thanks alot everyone, we used the pipe method and everything is good. NO more bad wheel bearing noise!!!
It's an "interference fit", meaning that you do have to apply some force to get it on. The best way is to get an aluminum pipe that is the same diameter as the inner bearing race, then use that and a hammer to get the bearings to fit over the axleshaft. If you want some help with it, I've got one of those pipes and some time to spare later tonight.
I'm acutally out in the valley now, yeah its not wanting to go on, I'll look into the pipe method... do you put anything else on before hand ,like the strut etc... or does it work best alone with nothing else attached. ????
got my wheel bearings changed, can't get hub back on shaft, and suggestions. Thanks so much Josh
Coolant in oil question
Posted
The car has 170,000, timing belt was done last April! I'll keep a close eye on it, hopefully I don't have an interal leek also.
Thanks
