jfulford1
Everything posted by jfulford1
  1. I replaced the fender; I did beat the core support down a bit to fit the fender better. jeff
  2. Hello. I've got a 1998 Legacy Outback. It runs great. However, that's about it. The car was in a slight front clip accident(left fender, headlight, and Control Arm). What works: Headlights/taillights, blinkers, Dash lights. What doesn't work: Brake lights, Dome light, radio(2 months old), AC blower motor, has ABS light. What I've done: replace relay, Climate control panel, blower resistor; blower motor works with 12V on it. Checked all the fuses I can. There is voltage to the Blower relay, but not down the line. Flashed the ABS codes and it indicated left rear area; replaced ABS sensor and checked tone ring; no go. Also replaced front ABS sensor; no go. Note: AC compressor comes on when blower motor is turned on; just no blower motor. Anything else I should try? The car drives fine(now pulls to the right; needs alignment. Thanks jeff
  3. Thanks all for the ideas! Going to balance the tires and see if that takes care of it. jeff
  4. At 89RU: No real noise with it. Front brakes just done; rears done about 2 years ago. Vehicle doesn't pull in either direction. It could be a tire balance issue. My wife has curbed them a few times.... At IVANS IMPORTs: Forgot about the U joints--but would wheel bearings be so specific about a speed and the ones I've replaced in other vehicles alway had a "drone" to them. Thanks guys. jeff
  5. I've got a 1997 Legacy Wagon with 120K(automatic). The car runs smooth up until around 65, at which point it has a pretty good vibration. I've rotated the tires and nothing seemed to change. Checked pressure, fine. Also, if I shift into neutral at 65-70, the vibration is still there. Not sure where to go from here. Any ideas? jeff
