2004 Impreza TS
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood point. Thanks for the advice.....have a great day!!
2004 Impreza TS
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks! You are correct, it's a SOHC. As for the wires, I usually buy Bosch and plugs are usually Autolite. What do you think of my choices? I'm a General Contractor who does remodeling. I can usually swap things out OK, but diagnosing is quite different.
2004 Impreza TS
I went to buy plugs and wires today. Clerk asked if it was SOHC or DOHC. I didn't know. How do I find out? Here are the first 12 characters in my VIN: JF1GG655X4H8. It has a 2.5L engine. Thanks in advance.
key broke inside ignition
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for all the info. I'll try one more time, then call a locksmith.
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunfortunately, the key broke off inside. If you could, I'd love to see info on how to remove the switch.
My wife snapped the ignition key inside the switch of my '98 Impreza. It has an automatic trans. Front wheels are turned hard to the right which makes towing it difficult. What are my choices? How do I remove the switch?
'98 Impreza won't shift out of Park
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSUCCESS! It was a blown fuse for the brake lights. Thanks to Sea and Imbew for the replies....you saved me a lot of headscratching Thansk again!
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsorry, but I'm a carpenter....LOL...where is the brake light switch located? Thanks!
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust checked the brake lights. They are NOT working, with key on, key off, and with engine running. Where would I start to look?
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok...thanks for the replies. I'll check it out in the morning.
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand if brake lights ARE working?.....then what?
My '98 Impreza won't shift out of park. Pressing brake pedal does not disengage shift lock. Any ideas? Can I disable this function?
MAF sensor specs
Hi......I'm looking for specs for a MAF sensor for my 1998 Impreza. I'd like to test it before spending $200 for a new one. Had a code PO102 pulled at Autozone today. Car keeps stalling while being driven. Any help is greatly appreciated.......Thanks
'98 Impreza codes
steve22l replied to steve22l's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool......thanks, Keith
'98 Impreza codes
Does the '98 Impreza 2.2 have self-diagnostics? I see 3 connectors under the steering column (2 green, 1 black). If so, anyone have the trouble codes for the '98 Impreza?........Thanks
steve22l
