jamin123
Everything posted by jamin123
  1. My local store don't have any and I've plenty time to wait for shipping. Where to buy online?
  2. I've a slight hesistant within the first minutes each morning. I park the car at work all day and I don't notice the hesitant any other time except in the mornings. It's hardly noticeable, but I'm curious as to what may be the cause. I would like to use seafoam with one of the vaccum hose to clean any corbon built up (assuming it's corbon problem), but I don't know which hose to use. Can I use the hose that's attach to the PVC?
  3. I reset using the battery info. on this site. The CEL light is off and I refill the gas tank and drove 30 minutes at 70mph. The good Lord is faithfull all the time!
  4. I found a ton of articles on google that seems to convey that I have a bad cat. I'm curious to know if I mess my good running car up by using the bloody seafoam and Redline fuel treatments. Also I change the sparks plug (bosch) 3 weeks ago. What's the going rate to replace Cat.
  5. Advance Auto Parts pull the code for me late this evening. DTC (Codes) P0420 Catalysis Efficiency Below Threshold (Bank 1) What this means? I hope no damage to the catalyst. I use Seafoam within a week after Redline. Maybe another tank of gas will flush them out of the fuel system.
  6. I've Advance autoparts in my city and they don't have much in terms of senor, sparks plug wire etc. Can I pull the code my self? I'm very technical and mechnical, but I don't have much tools? Is it too complicated to install a universal senor? What's the difference between universal and oem parts?
  7. I've a 1995 Legacy L. Sedan (2.2 I think). I need a oxyen sensor, where to buy online? My car was runing very good, but yesterday I put a little sea foam in the gas tank and today I got the "check engine light", could that damage the oxegen sensor? I last change sensor 3 years ago. There is a slight hisitand when I first start off in the mornings and I saw a little bit of carbon in the sparks plug wire, so I change the sparks plug, but couldn't get any wire at my local stores. Still has the hisistant so I put a little seafoam in the gas tank. I merely trying to tune up before winter, but may screw things up, did I? How often should I change coolant sensor? Do they have car manual in ebooks?
