Everything posted by Nosferatu
1994 Jap spec/import Legacy turbo no o2 sensor.
Nosferatu replied to Nosferatu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate: I found the wiring for the o2 sensor at the ecu and traced them into the engine bay. It appears the plug was cut off. Possibly by the previous owner when he installed the exhaust temperature sensor. Thanks for the help anyway!
Nosferatu replied to Nosferatu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo matter, iv gone to the wrecking yard, pulled the wiring from the ecu connector and out of the loom. Going to wire that into my car and be done with it.
Nosferatu replied to Nosferatu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have got a 3" down pipe with the bung after the cat. I can weld another one where you said if necessary but I still don't know what to do with the wiring. According to the ecu pinout diagram there is a shielding wire that connects to the ECU as well as the signal wire from the o2 sensor. The shielding wire is shown as if it goes around the signal wire as a dotted line but doesn't connect anywhere else. How do I wire an o2 plug with that shielding wire? (Where does it go to after the ECU? Maybe there is a way to avoid connecting the shied and just wire in the signal wire?)
Nosferatu replied to Nosferatu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure.
Nosferatu replied to Nosferatu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it is the single turbocharger setup. It has a 2 wire plug in the loom that looks stock that connects to a temperature sensor after the cat. No other bungs for other sensors and I can't find any other plugs for an o2 sensor. Is there a way to maybe wire in a plug?
Hi, I am at a loss over my newly built subie. I have rebuilt an EJ20G Turbo engine with some WRX Sti heads, race spec bearings and timing belt, bigger turbo, 3" exhaust, sti injectors and other goodies. It is running like a dream with one exception - 200kms per tank and low power. It is running an after market ECU (Link G1) off a 96 WRX with a road tune. The ECU obviously requires an o2 sensor to be fitted on the vehicle to adjust the mixture. After looking for the bloody connector to an o2 sensor in the engine bay, I looked at the old down pipe and realised there is an exhaust temp. sensor but no o2 sensor on it. I have never heard of a subie without an o2 sensor, and there is no information available online. (as far as I can tell) Can someone please tell me, am I going insane or do they really did not have an o2 sensor?? Thanks in advance!
