rboyd
Everything posted by rboyd
  1. smelling gas and check engine light at the same time. I'm no mechanic but I would check everything related to fuel, from the filler cap through the tank, fuel lines, pump and filter (as you mentioned) to the injection system. any of these could turn that light on and none of the repairs would be that major
  2. 98 Legacy Outback Limited, manual trans. I thought my battery was dead this morning when I attempted to start it but it must be a different issue as after charging the battery and no change. I actually switched a battery from the other car to see if there was a difference. Chime is strong and loud when door is open with key left in ignition. However, no dash or idiot lights come on when ignition is turned to on position and the interior lights don't work. The only electric item that I can witness is hearing the chime. Is there a fuse or relay somewhere that could be causing this?
  3. 98 Legacy Outback Limited, manual trans. I thought my battery was dead this morning when I attempted to start it but it must be a different issue as after charging the battery and no change. I actually switched a battery from the other car to see if there was a difference. Chime is strong and loud when door is open with key left in ignition. However, no dash or idiot lights come on when ignition is turned to on position and the interior lights don't work. The only electric item that I can witness is hearing the chime. Is there a fuse or relay somewhere that could be causing this?
