2002 Outback 2.5 manual transmission, 139,000 miles. What i have is a noticeable play in the drivetrain. This is most annoying and evident when going down long slight grade hills at freeway speed. Cruise control lets off and you lean forward in your seat, you slow down a bit cruise kicks back on and it snaps you back. I have had this car since it rolled over the 100,000 mile mark and it has been the same. No other car I have owned, and they have just about all been manual shifts, ever did this. I have changed the clutch, and both front drive half shafts to no avail. What I am looking for are some simple checks to rule out the transmission, the front or rear differentials, or the coupling. Some mechanical part is taking a beating and I would like to replace it before it fails at the worst possible time and place. I suspect it is the transmission as the effect is more noticeable as you get into higher numbered gears. It does not grind, vibrate, or grab whilst making sharp slow turns. Problem is just as noticeable with cruise control turned off. If anyone has had this problem and it was the transmission, is there anywhere to send it off exchange for a rebuild.
