cenatnelson
Everything posted by cenatnelson
  1. Where can I buy new cams for a 1987 ea82 ? Close to Colorado.
  2. Thanks for the link ,I watched and did everything correct. I have changed these belts in the past with no problems. This all started when I was driving up a hill and shifted gears, car started misfiring with no power , so I turned around to go home and it backfired very bad coming down hill. I did the usual new plugs ,wires, cap and rotor plus new fuel filter to no avail.so I checked the timing and found it to be way off. The belt on the drivers side will not line up with marks. When you install belt with dot on cam sprocket up and flywheel set in to the middle mark then turn crank 360 to do other side then back to check driver side belt with dot up the three marks on flywheel will be about an inch to left of pointer which throws everything out of whack then you cannot time distributor correct.
  3. I have a 1985 gl wagon which the ignition is way out of time. I changed the belts and could not get the center of the three marks to line up with timing mark on cam on driver side, also distributor is out of adjustment and I cannot time with a light. I checked to make sure the cam sprocket was on correct and also changed distributors with no luck. any ideas ?
  4. What does that mean? I am looking for 4 hole 14" rims to fit a 1985 GL wagon!
  5. I have a 1985 GL wagon with 13" wheels and the 13" tires are becoming very hard to find, So I was wondering if there is a 4 lug 14" wheel that will fit the GL ?
