1987 gl wagon headlight issues
I've swapped the relays under the steering column and looked for loose wires with no luck. Sometimes when I'm driving the lights just cut off..but I'm pretty sure it's done it more after turning brites off. Also sometimes right when i turn my lights on there is a delay till the lights come on or if i have to turn off and on real quick or flash the brites to get them to work.
I bought the car 9 yrs ago and haven't changed any myself till recently to see if it would fix the problem but it didn't. It's been happening for like a yr now. Not sure what's causing the issue. Could it be in the blinker and light switch from the column somewhere? Seems to happen more when I'm turning off the brights flipping turn signal and light switch.
- 1987 gl wagon headlight issues
5jx13
Will all 5jx13 rims work on my 87' gl?
New clutch
Thanks for the response, I just had never replaced a clutch and had no clue on what I'm doing. I pulled the engine last night.. Got that step out of the way.. But I need to get the flywheel resurfaced this week and I will be putting it back together next weekend. All I could find on here was for ej conversion diameters. I got an excedy 15008 clutch, so is it no more then .03 off the flywheel at the machine shop?
New clutch
I'm putting in a new clutch in my 87' gl wagon 4wd, what should I get flywheel resurfaced to?
ea82 fwd clutch replacement
- running engine oil drip?
First time posting .. I have a 87 gl dr with a weber installation I have done with the help from this great place. Problem I'm having is when I have the motor running its dripping oil from somewhere pretty sure it isn't the oil pan.. took a pic #1 is like a 10-15 sec drip.. #2 is just showing another drip ..ideas?
cornbreadfed
