Shaunald
Everything posted by Shaunald
  1. and im sorry for not posting the pic of the clip myself i can not figure out how to upload them on here (i tried)
  2. but if the rod came undone how could the car still go to drive and the park work?
  3. so i can get an idea of what the specifically the clip does and goes on? :/
  4. i did not see anything disconnected. but on the flat spot behind the clip half it is warn darn where the piston hits on it? im not to sure exactly what the clip is called because i am thinking i need to find one online due to i can not find mine now. > do you have any pics of the vb with that clip attached??
  5. yes that clip in your pic is the one i found in my pan, but the rod does not look the same, the rod that i see come out does not have the groove in it and is on the back side of the tb on the passenger side.
  6. i have had someone shift it through the selector. it an automatic car :/ and when it was off i noticed a rod that kept moving out and id push it into the valve body for it to just spit fluid out at me.
  7. I Have had someone shift the car while i watched it at the transmission and i physilically grabbed it and shifted it into drive, reverse, etc. every gear is now drive. in park it is parked. nuetral is drive as well. but when i took my tranny pan off i found a clip in it. and it kind of drive like crap. it felt like ithad slippage in it and other junk. not like it was when the gears works, i showed someone the clip and they said they recognize it as a reverse band clip?
  8. Alright. Well i tried a fuse and got no light. I replaced the transmission filter and fluid. I now have response from my transmission. Except it only goes forward. Drive, nuetral, reverse, 1,2,3, all go forward. What is going on here??
  9. This was very helpful reading this forum. I to have the at oil temp light flashing except i lost response from my transmission. I also have put the fuse in the fwd spot and nothing shows on the dash. But what is the correct amp size for the fuse for the fwd?? I will definately try the code thing tomororrow after work. Thank you guys.
  10. Ok, so i have a 96 legcy that has a swapped out engine from a 2.5 to a 2.2, well I have been driving it for awhile now and today I was going to work just like all the rest, had the radio on and the cruise set. Well I started to go up the hill and the car down shifted to climb it but as it did that the engine revved real high as if the car went into nuetral. So I pulled over due to the car lossing speed. So I put it back in back then tried all the gears, NOTHING!! O.o it just dies out of no where. The transmission has never slipped, made any nioses, hard to shift, etc. Just gave out. Put the car on jack stands and reved the engine in drive and reverse andthe wheels moved alil like they wanted to move, but then put the car back onto the ground and nothing. Has anyone else experienced this? and what could it possibly be, blown clutches, bad gears in transmission, low fluid, bad torque converter?? Please help me. It is my only car and I work as much as i can to make ends meat.
  11. Hi my name is Shaun, I am 20 years old. I recently bought my first Subaru (I'm used to Chevy and cars like that). I like the car but I have an issue with it. When I traded my truck for it to save gas and money I drove it home about 33-40 miles and after filling the tank the check engine light came on for a P0403 code.I thought it might have been just due to over filling the tank. Well after resetting it and driving another 40 miles the light came back on again. So I contacted the guy I got the car from and he then proceeded to tell me that the engine is not original and was swapped out for a 2.2 and its supposed to be a 2.5 in the car. He told me the car passed NY inspection with that engine in it. The 2.5 had the egr valve system but now this 2.2 does not have that. We tried switching the computert under the passenger side floor with a 96 2.2 non egr computer. It still came on. I called the guy back and he said it common for a relay to be causing it on there. But I can not find a relay there for it or anything on it. Can someone out ther please help me resolve this???? Like I said I'm only 20 so I dont have another vehicle and alot of money. Thank you.
