Ngurdak
Everything posted by Ngurdak
  1. Btw I listened to the injectors and herd a ticking so I assume there fine
  2. I've had it for today! Beers and a BBQ calling this stressed out mans name! AMERICA!
  3. Could any of this be related to a clutch job I had done a week before this started?
  4. It sure was the negative lead! Car starts But car continues to sputter and die. P 0301 p 0302!!!!! Maybe ecu, some sensor or ignition? I can keep the car running if I hold the RPM higher than 7 once I let off it putts and dies
  5. Haha ya I am changing my batt leads today they are a bit corroded, but were not an issue before... Battery is newer. I will b replacing today and will post results! Thanks
  6. I also have this prob! My 2005 forester x threw a p 0301 and 0302, I replaced plugs and wires and it didn't fix . The car would still sputter and stop! I went to Subaru for a replacement coil $140 and after installing it,I turn thee engine over the car goes z... And then the power no longer works unless you un plug the negative on the batt and re set. Is there something I'm missing that would cause the new coil to behave like that? Like a reset?Use more dielectric grease? 3 bolts, 4 spark wires and a plug that was it. Spark Wires are in the correct order!
