dutch
Everything posted by dutch
The cross over pipe is cracked, I guess I did not look closely enough to realize the exhuast input to turbo is from both sides, I'll have to look closer. I'm pretty sure I didn't say The turbo wasn't performing only that you can't feel any boost in the condition its running in. So if the turbo light comes on does that mean the turbo is working and changing the manifold pressure enough to activate the light or is it activated by normal manifold pressures that can be reached without turbo only at higher RPM? So the turbo light might come on at 2000-2500 rpm? Where is the MPs located? Subieman, where did the metal come from, were the fan blades tweeked and hitting the sides. Will you explain what was happening to your rig and the change after repair. Was it significant? I replaced the turbo unit about 4 months ago (with used) because the old fan was squealing and shortly after my problem began.
Cougar, I live in Valdez. If I thought that it could make it to anchorage I would take you up on the offer instantly my next trip, but I'm not sure that I could make it up Thompson Pass as I have not gotten the power back, not even a short boost for 5 days or better. Thanks a lot for the offer. Next time I go to Anchorage I'll let you know and maybe we can get in touch. Now, I have injector pulse, compression, and I tested the EGR it appears to be working fine. I'm on night shift and my wife did not pick up the plugs and wires for me today so maybe tomarrow. The resistance on the wires from shortest to longest was 3kohm, 5kohm, 16kohm, 17kohm. The 16 and 17 are of course the pass. side but the too are about 3 times longer than the others. Two short blinks on the computer is a 2 correct and was does this code signify? The engine light comes on only when exellerating and goes out when I let off the gas for the first 2 or 3 miles then it comes on solid till I shut it off then it is gone again when I start it. This indicates a soft code rather than a hard set code correct, making it harder ti diagnose with code reading I think. As for earlier questions, the turbo works off the pass side exhaust, and the turbo light works or at least is coming on but I think this simply works off of the gas pedle position not the actual boost condition as when it comes on (in the same spot no matter the conditions) there is abviously no boost
Is it possible for the pass. side timeing belt to be off
I had done all 4 cyl. They were all between 115- 120psi.
Loyale acceleration hesitation
dutch replied to Phaedras's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did anyone ever figure this problem out. Mine is doing the same thing and I was hoping that since the [posts stopped the problem had been resolved and you just forgot to post the fix. It would be a dream if you could tell me the magic potion. Thanks Dutch -
My passenger side plugs were dark and wet when pulled. A sign they obviously were not doing there job. The drivers side were both whiter than brown, a sign I think they were doing more work than they should be and getting hot. You would think that would indicate the wires were bad or the plugs fouled only when tested I get fiarly strong spark from both plugs and wires. Makes me wonder why they are wet and obviously look as if not firing when installed. The compression is good with the shrader valve in the compression tester. I have not done a running compression test, but feel with these test it may not be nessesary. The Question is why are the plugs not fireing in the cylinder. Some kind of condition in the cylinder may be cuaseing this. Of course I feel as if I am ranting and getting out there in left field. Could be somthing very simple. That would be nice. Just thought I would give you the newest information. Thanks agian for the help any other advice is much welcomed and definately still needed. Dutch.
Northwet, Thanks for the input. I replaced the cap rotor plugs fuel filter snd oil, with little change. I will change the plugs and wires tommorrow. First I will check the resistance on my existing wres. Do you know what it is suppose to be. You don't think that the exhaust could be plugged do you. When I say it has no power then...Bam the power is back I mean bam. In a heart beat if you keep the pedle at the exact same spot in first gear it is lugging then just instantly you are picking up speed just like that. It seems like electrical is all the sudden making a connection or somthing electrical is all the sudden doing what it is suppose to be. Maybe the mass air flow sensor? Do you know how to check this on a Subaru and what the specs are. ANY other suggestions are much appreciated, Thanks again. Dutch.
I have a 88' turbo Gl 10 that lacks any power at all. I thought that It was a head gasket cuase thats what it acts like. Can hardly make it up a curb in 1'st gear but then I was driveing and all the sudden the power came back and it took off. for a few days when I started it for the first 200 yards no power, Idle at 600 RPM then bam the powers back. If I shut It off and restart no power for two hundred yards then bam. Well I let it sit during my week off. I went to drive it to work after a week and it has no power again. I think it has to do with the pssenger side of the engine. When it is acting up I can pull both passenger plug wires with no difference in RPM I pull just 1 on the drivers side and it dies. I know the plugs have spark. So is this a intermittant ecm problem with the pulse and the passenger injectors or a fuel pump that is dieing and the drivers side gets the fuel first since its first in line in the fuel delivery. Or is something totally simple that I have overlooked. Please any help is much appreciated, my mileage sucks, and at $3.15 a gallon its killing me. And only being able to run in 4'th on flat highway and not 5'th is driving me nuts. thanks in advance. Shannon
