notruck
Everything posted by notruck
  1. Is it just a pop in? with all the wires and other connects?
  2. I can see the belt turning. When trying to start. This is 2.5 and I was driving going about 50mph at the time. So I'm thinking the valves are damaged. Because the belt is turning! Is this what you guys think? Thanks Much Dave
  3. well I pulled the first plug out and did the test...And no compression guess the engine is gone!!! Guys is it worth the time to do a rebuild? It had 235000 on it.. Thanks for your time Dave.
  4. Do I need a specific compression tester for this? and what should the compression be? Thanks
  5. Thanks would it easy er to pull the front of the engine apart and pull the covers to the belt? I did put a new belt on last year with new pulleys and water pump. Thanks
  6. I have not pulled the front covers off. But I can see the belt turning.
  7. my 1996 outback will not start. As I was driving yesterday it quit running. Im getting gas (pulled the gas line off and cranked it over gas came out. I also sprayed some starting fluid in the intake. I have spark @ the coil.. It turns over good no back fire. any help 235000 miles on it I changed the timing belt last year and I can see that its turning..
