Everything posted by junkmanjason
Help ! My 1989 gl sw 4x4 won't start. I have fuel and spark so do I need a new ECU? Are they the same for ea82 standard or auto?
I'm having problems getting it to fire . I got a new starter ,fuel filter .Did the spark plug test and have spark. Where is the crank angle sensor ? I did my belts last year when I put in a new oil pump and drove everywhere with it and had no problems . I'm at a loss .
I need front cv shafts for my 1989 GL SW 4x4 . What are the best ones on e-bay ?
I'll only do the ebay thing .
Looking for help getting the right front cv shafts for my 1989 GL SW 4x4 . It has an EA82 with a dual range 5 speed . Looking to buy them off e-bay.
Dumb question , I have the SJR 2 # lift for my 1989 gl sw . Which way do they face in the strut tower,pics?
Cool I found it out from pics and just got back from a week in the woods with the Subaru. Thanks for the help Scott your lifts are great !
Hi I kind of need help finding out how the SJR 2# lift fits in the tower . The pictures I have seen show the SJR on the lift faces outwards to the fender . The ones I got that won't happen . Did I get the wrong ones ? Anyone have pics of the lift in the tower? Thanks ,I really need help on this one .
A new ea82 oil pump ,does it come with the shaft seal or do I have to put one in ?
Thanks for the help on this one . It's my first new oil pump on ea82.Saved me some time ,thanks again !
Hi I was just wondering if a new genuine parts Fuji Heavy Industries oil pump for a ea82 needs a shaft seal or does it already have one ? I know I have to put the other two seals on but I don't want to take things apart to put the shaft seal in if I don't need to .
HELP EA82 ROCKER NOISE !
I might just get lucky and only need a new pump. I'll try that first . Thanks for everything !
Thanks for all the help guys . We did the cam tower o ring thing when we did the belts . Also the mickey mouse gasket for the oil pump .First time the gasket got messed up so I had to get another one. It was done right the second time "Hahaha".I think the oil pump is just weak.I think that will be my first step .I hope that's what's wrong then I won't have to touch anything else .Thanks again !
I'm thinking it's time for a new pump but lifters might be part of the problem also . I'll look for that fuel additive next fill. I'll check for the oil passages and give that a try too.Is there a cheaper place to get a pump and lifters ?Thanks for all the help.
It's been happening for a while ,about 3000 miles . It was hard to hear in the winter with the heater on and the windows up . Now the weather is better and the windows down it sounds bad .Oil is fine and golden ,no metal . No overheating or anything. I could try and make a video of what it sounds like .
Hi the run lean condition was that on an injected engine? How did you fix it ?Thanks for the help!
The engine light works and doesn't come on .The plugs and wires are less then half a year old.When we put the mickey mouse gasket in do you think it didn't seal right ? The engine isn't ticking when idling .I'm going to try the belts ,next will be a new pump and gasket . We did the cam tower seals but that will be my next check .It has 230 000 km and was front wheel drive so it was never off road .It passed air care with flying colors after we did the work . Thanks for all the help saving my 4x4 sw.
Thanks for all the help ,I'll give it a shot .I hope I didn't damage the engine. I've been driving it for months like that. It seems to have less power than it should also . It's my first Subaru build so do you think I should pull the engine again to do the timing belts ?I'll try cleaning the pressure relief pipe also . Thanks again!
Under load my 1989 subaru gl makes rocker noise . Sounds like valves need adjusting but I don't think they are adjustable or are they ? It has a new oil pump seal .It's not ticking or anything . I did the belts + and cam seals . It sounds worse with lower grade gas . Is my timing just off by a bit or just bad rockers .Almost sounds like it's dieseling.It only has 230 000 km.It runs and drives fine with no back fires.I really need help on this one,thanks!
ANYONE HAVE A GOOD USED 2 INCH FRONT LIFT FOR 1989 GL SW THEY WANT TO SELL?
LOOKING FOR A GOOD USED FRONT 2 INCH LIFT FROM A PERSON WILLING TO SHIP TO GOOD OLD CANADA.THANKS AGAIN .
HELP I NEED A GOOD GAS FILLER TUBE FOR A 1989 GL SW
I'M LEAKING GAS WHEN FILLING UP . LOOKING FOR ONE THE WILL FIT AN 1989 GL SW FROM SOMEONE WILLING TO SHIP TO CANADA.THANKS.
What is a good start up idle speed for a 1989 fuel injected EA82 gl ?
Cool thanks for the help !
Thanks for all the help with this .I'm really glad everything is O.K. with my idle speed.
It's up at 2000 rpm at start up ! Is that to high ? Is there a way to turn it down a bit or is it O.K. at that speed ? Thanks for the help .
I need a front 2 inch lift kit.A full set of Peugeot 15 alloy lug nuts and a good gas filler tubefor a 1989 gl sw . Then my subaru is done!
Would 195 60 15 tires work in the front without the lift kit?Thanks .
Cool thanks so much I'll try them out . Do the stock Peugeot lugs fit the Subaru ? Will I need the 2 inch lift in the front first or will they fit now ? I got the wheels for $150 .Thanks for the help .
I started from a shell and did everything that could be a problem . It runs and drives like a dream .I just need the 2 inch lift ,pug lug nuts for the 15 alloys ,a gas filler tube .Thanks for the help.
BOSS 2" EA82 Lift Kits- $100!!!
Hi Bill Are you making anymore ? I just need the front lift too .Lugs for my pug 15 alloys and my gl sw is done !
