- 1999 Impreza Body Rust
Hood for 1999 Outback
My wife hit a deer in my 99 Legacy Outback last night. Only damage is to hood and grill. I am looking for used parts. Can I use parts from any other years?
1999 Impreza Security System Reset
Changed battery in 99 Impreza and now starter won't turn. Can anyone tell me how to reset. I do have the remote fob.
Flashing Check Engine Light
Driving home last night, 1999 Subaru Legacy Outback 2.5 was running fine when all of a sudden it turned rough and Check engine light started flashing. Previous to this, there had been some very intermittent missing, which my mechanic attributed to bad gas/clogged injectors. I ran some Sea Foam through and everything seemed ok.Apparently there is a cylinder not firing. Any ideas on where to start?
- What Engine Do I Have
What engine came in 1999 Legacy
I have a 2.2 SOHC engine from a 99 Legacy. I believe it is an EJ222 Phase II, but how do I tell. I need to know so that I can sell it. Also, what other Subarus can I swap it into?
Changing 2.5 DOHC for 2.2 SOHC engine in 1999 Subaru Outback
So what car did the EJ222 and Ej223 come in?
So what engines actually came in the 1999 Legacy Outback?
I can get a 97 2.2, so that would be plug and go?
I know that he did cut and splice the wiring harness
Engine is a used 1999 2.2 Legacy Outback not tested.
My mechanic is changing my 2.5 engine for a 2.2 engine in my 1999 Legacy Outback. The job is almost complete but he is only getting fire to two plugs. He changed the coil to a 2.2 coil, but then he had no fire at all. Please help. I need my car back!
Changing 2.5 DOHC for 2.2 DOHC engine in 1999 Subaru Outback
My mechanic is changing my 2.2 engine in my 1999 Legacy Outback for a 1999 2.2 engine but we have encountered a problem. At first we had fire to only two cylinders. Then we changed to a 2.2 coil and had no fire at all! Do we need to change the computer? This job is almost finished but we need help!
catsdaddio123
