catsdaddio123
Posts posted by catsdaddio123
My wife hit a deer in my 99 Legacy Outback last night. Only damage is to hood and grill. I am looking for used parts. Can I use parts from any other years?
Changed battery in 99 Impreza and now starter won't turn. Can anyone tell me how to reset. I do have the remote fob.
Driving home last night, 1999 Subaru Legacy Outback 2.5 was running fine when all of a sudden it turned rough and Check engine light started flashing. Previous to this, there had been some very intermittent missing, which my mechanic attributed to bad gas/clogged injectors. I ran some Sea Foam through and everything seemed ok.Apparently there is a cylinder not firing. Any ideas on where to start?
So did the H-4 Boxer come in Phase I and II? Can you still tell the difference by the valve covers?
OK, I checked the valve covers and I definitely have a 2.2 Phase II engine from a 99 Legacy. I want to buy a 99 Impreza and replace the 2.2 H-4 Boxer currently in it (blown head gasket) with my 2.2. Is this a plug and go swap?
I bought a 2.2 SOHC engine from a 99 Legacy, and am not sure which engine that I have, or what cars it can be swapped into. Can anyone help me figure this out?
I have a 2.2 SOHC engine from a 99 Legacy. I believe it is an EJ222 Phase II, but how do I tell. I need to know so that I can sell it. Also, what other Subarus can I swap it into?
So what car did the EJ222 and Ej223 come in?
So what engines actually came in the 1999 Legacy Outback?
I can get a 97 2.2, so that would be plug and go?
I know that he did cut and splice the wiring harness
Engine is a used 1999 2.2 Legacy Outback not tested.
My mechanic is changing my 2.5 engine for a 2.2 engine in my 1999 Legacy Outback. The job is almost complete but he is only getting fire to two plugs. He changed the coil to a 2.2 coil, but then he had no fire at all. Please help. I need my car back!
My mechanic is changing my 2.2 engine in my 1999 Legacy Outback for a 1999 2.2 engine but we have encountered a problem. At first we had fire to only two cylinders. Then we changed to a 2.2 coil and had no fire at all! Do we need to change the computer? This job is almost finished but we need help!
1999 Impreza Body Rust
Posted
My 1999 Impreza has a bad rust issue around the rear wheel wells.. Since it will not now pass state inspection, I must either fix this problem, sell the car, or buy a comparable car with a blown engine, and do a engine swap. Any input would be great. It runs great with cold a/c!
