JayW
Everything posted by JayW
  1. Okay, so I drove it for two days with no AT light, then yesterday (after a 20 minute drive at highway speeds) it came on after restarting the car to check. Checked the codes... 24 (Duty C), with no 32 (VSS1). Just drove in tight circles, no torque bind. Shifting feels really good after all of this new ATF I've been putting in. I don't really get it... If the duty c were failing, I would get torque bind and the FWD fuse would not work, right? I was really hoping it was a bad VSS that was messing up everything like you said, fairtax4me, but it doesn't look like that is the case. It appears that the problem occurs when driving at highway speeds. Something strange that I've noticed is that the engine temp gauge always reads warm (normal operating temp), even when starting on cold mornings. Weird. Wiring problem? Coming from my 2002 VW, where sensors go crazy all the time and signal the CEL, I'm surprised that I'm not getting any CEL codes for things like this. Normal?
  2. I just cleared the codes and will drive it this afternoon and then check the codes again. The FWD fuse does work: FWD light comes on and it is indeed in FWD. Driveshaft and axles are all good. Brake lights are good, but there was some corrosion on my driver's side, so I cleaned that up. Yesterday while driving up a mountain road, it dropped out of gear. I let off the gas, then put it back on and it went in smoothly, with no other problems for the rest of the drive, which included some steep gravel hills, so 4WD was definitely working well. This is the first time (that I know of) for this to happen. I had just drained and filled the transmission again, and I had it a little bit low on fluid. Hopefully this was the cause. Thanks for the tips, I'll report back after driving and checking the codes again. I'll also check out the ABS business.
  3. Hey, this is my first post! So go easy on me! My girlfriend bought a 1996 Legacy L 2.2 automatic with ~195k on it. It appears to have been taken good care of for most of it's life. After driving it for a few months, the AT oil light started flashing 16 times at start-up every once in a while. Now it is pretty consistent and she finally decided to tell me. After researching (thanks, for the info, everyone), I did the diagnostic and got codes 32 (Vehicle speed sensor 1) and 24 (Duty c). I've never worked on at AT and am intimidated by them. I've changed the fluid, cleaned the grounds, etc, with no changes to the problem. I am not getting any torque bind on tight corners. The ABS light is also on all the time with codes 52, 51, 31, and 11. Any recommendations before I try to replace the sensor and solenoid? Anything that might be worth checking? Thanks in advance!
