roobaroo
  1. I recently cut the rust out from behind the rear wheel into the cargo boxes and turned them into toolboxes
  2. Could it be my ignition when it was running i could turn the car off and it would run for a sec an die while the key was off
  3. And there is no power coming from the wires going to the coil and no power comingfrom the wires going to the disty
  4. There is no power so here is a question could i swap the disty with one that has a ignitor on the coil braket and use a toyota coil and ignightor?
  5. Its not on the coil bracket anywhere
  6. Thank you for looking i have a 1987 subaru dl carb motor ea82 i cant get fire to the coil it was running great got in it one day and it had a bad miss wouldnt hardly run after it got to running temp it would die and not start back let it set for about 30mins start it drive it a little way and die again finnaly got her home and it wouldnt start at all put a accell coil off a ford truck on it it ran for a couple of days and just died never started back no fire any where changed coil still no fire im stumped any help would be great the disty has 2 boxes in side hitachi denso i think 2 wires come out into a round plug to disty and ftom disty to another round plug to under dash sumwhere ??????
