Everything posted by benking
power steering noise
Recently my 2000 Legacy GT has had a loud squelling noise coming from the front when I turn the wheel. The odd thing is that it only happens after the belt or engine has warmed up for a while. Could this be the belt expanding or a new belt needed or what? Its just an annoying sound that sounds like the power steering is over-working its self. Also could it be something to do with the power steering fluid? Ben
front end noise when starting off
benking replied to benking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt actually only seems to be when I am making left turns. When making right turn I hear no sound. Ben
I am getting a front end noise when starting from a dead stop at a light or stop sign. It seems to only be happening when the cars wheels are pointed straight. The noise is getting slightly worse as time goes on. It sounds like 2 things rubbing or a part very worn down. I was wondering if it could be shocks, but i think it is something in the steering or tie end rods. Any help would be appreciated. Thanks Ben
steering question
Today while I was driving my 2000 legacy gt I noticed that the wheels are not recovering to straight after making a right hand turn. It just stays turning to the right when i take my hands off the wheel. It mkes left turns just fine and returns straight. Is this an alignment problem or something to do with the universal joint on the right. An help would be appreciated. Thanks in advance Ben
front end noise question
I have a 2000 legacy limited. I have been having a vibration/thump inside my car that sounded like it was coming from the back of the dash for quite a while now. Tonight i had the window open and it sounds like it is actually being created a brake or axle or something down there. The noise is kind of like a thump every second or so. It doesn't matter how fast the vehicle is going it still makes this sound. Sometimes the noise gets obnoxiously loud inside. Any help would be greatly appreciated. I would like to get this fixed as soon as possible because I drive my car 150 miles to school each way every week. Thanks Ben
K&N air filter rattle
benking replied to benking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have checked the filter box already. I think it also does it when the engine is hot Ben
Subaru recommended timing belt replacement
benking replied to benking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe timing belt service interval isn't in the owners manual. Ben
Subaru recommends changing your timing belt every 105,000 miles on a 2000 or newer model. Do you think this is right or should it be done more often? Will it destroy the engine on a 2000 legacy if the belt does break? I found that service interval here: http://www.cars101.com/subaru/subaru_maintenance.html Ben
benking replied to benking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdo foam filters work very well? I was thinking about trying one Ben
benking replied to benking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit sounds like a panel rattling...and continues to you let off the gas at high speeds. it is a panel filter. Ben
resetting CEL
OK, how do you reset the CEL on a 2000 lagacy gt? Thanks Ben
MAF sensor
How do you reset the MAF sensor on a subaru? I have a 2000 legacy gt limited. Thanks Ben
I installed a K&N airfilter in my 2000 legacy gt limited a few months ago. Is it nornal to be hearing a rattle noise when the accelerator is pushed now? Is there a fix for this? This noise only started once the K&N was installed. Or is there another brand of air filter that people would recommend and not make the rattling noise? Thanks for the help Ben
spark plug wires
What are the stock plug wires on a 2000 subaru legacy gt? What do people recommend putting in if i am to replace them? Also there is no distributor cap for this engine is there? Thanks for the help Ben
smell
after i installed new belts on my 2000 subaru legacy gt i am smelling what smells like the belts...is this a problem or is this just normal with new belts for a while? Thanks Ben
loud squeel
benking replied to benking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe car isn't making a squeel anymore...so i dunno what was going on... Ben
loud squeel
I just replaced both of my belts (ac & alternator/ p/s) on my 2000 subaru legacy gt. I just took it out for a spin and heard a loud squeeling noise. It was only doing it when i accelerated. Is this normal with new belt? Or could they be too loose or tight? Ben
spark plugs
Does anybody know what the stock spark plugs on a 2000 subaru legacy are? Can i upgrade to bosch-platnum spark plugs? Ben
Replacing alternator p/s belt
My alternator & p/s belt on my 2000 subaru legacy gt is making sounds. I am sure it is time to replace it. It also has cracks in it. Does anyone know how this is done?...because i don't see a tensioner on this belt. Is there any special tools needed? Ben
pcv valve
I have a 2000 subaru legacy gt limited. I am trying to find the pcv valve. Does anybody know where it is? Thanks, Ben
carfax report
Could someone with a carfax or any vehicle history report subscription please run a report for me and send it to me...I am looking for a pretty detailed report if possible. My VIN: 4S3BE6565Y7210431 Anyone that can help please. Thanks
Transmission flush
I have a 2000 subaru legacy gt limited. I am not sure that the transmission fluid has ever been changed. At what mileage should the vehicle have a transmission flush? The vehicle has about 61,000 miles on it. Also can I do a transmission flush on my own or do I need to take it to a shop?
subaru legacy transmission dipstick
does anyone know where the transmission fluid dipstick is on a 2000 subaru legacy gt limited....i can't find it...the manual says it is to the left of the air filter but i can't find where it is located...any help would be greatly appreciated.
