stonedmonster
Posts posted by stonedmonster
Yea I plan on it, just don't have the money for one at the moment.
I have recently put an aftermarket ignition in my 93 loyale because the previous owner has messed it up badley and I don't have the money to buy a new part so I went aftermarket. I have it working fine but theres a red/black wire that was marked R one the original ignition and when ever it gets power it reves it up to 2100rpm were it should be when its cold and warming up but it wont kick back down to 1100rpm were it idels when warm, what does this wire do??? and were should it go?? I could really use a diagram if anyone has one. thanks.
I need a ignition wire diagram, or if anyone knows what each wire is.
it is a sedan, the motor is at the base of a door I tryed to unplug it bit it dident seem to be the right one ill have to pull it off tomorrow. no I have not checked the pcv valve yet eather.
the light wasent a big deal just dident see it at first. Doesn't seem to be anything related to air intake, the filters like brand new and all the plumbing seems to be fine the connection is clean. I'm thinking I'm gonna change the rest of my plug wires next two are new the rest are original. Also does any one know how to cut the power to the electric seat belts they don't work as someone has messed with the ignition but the passenger one still has power and it makes a weird noise and I can't find a fuse for it. I just want to cut power to it till I get a new ignition installed.
haven't had time to do anything yet to find the issue but it DOES have a check engine light on. the previous owner had put black tape over the light
I am not familiar with pulling codes on thease old soobs how do I do that?? and if it had a code would the check engine light be on?
Okay that's were ill start, and no check engine light. it does better after she's good and warm its not as bad as when its cold. when its warm I can hold the pedal down and it will bog down pretty bad but if If I keep holding it it comes back after like 30sec
okay, I did not think it would be fuel unless its getting to much. It runs great it idles smooth and I can drive it but got to take off slow if I push the pedal to hard it just bogs down really bad or if you rev it, but I can rev it up if I just push lightly. it looks to have a new fuel filter in it and the pump don't seem to be making much noise, Someone had suggested the throttle positing sensor would that cause this??
Hello I am new here I just bought a 93 loyal fwd 1.8l 5 speed and it is my first Subaru. It has a bogging out issue when speeding up it idles fine but if you push the gas pedal down more than about an inch it bogs out, it does it in all gears. I am clueless it runs fine just got to accelerate slowly, anyone know why??? anything helps thanks.
ANYBODY know anything about ignition wires?
Posted
cool thank you guys it works there and runs as it should =)
