First, thanks in advance for any assistance with this fuel pump problem.
Short problem description - I have power to the fuel pump plug briefly at key on and when the engine is cranking. The pump does not run.
The pump and the fuel pump relay have been replaced. The new fuel pump is a turbine unit from Napa. The is continuity from the connector through the pump motor, reads near a dead short. Do does the old fuel pump.
The only thing I can think of that would be a problem is the electrical connector at the tank (fuel pump and sending unit. I found a small brass near the plug just before I took the pump back out ofthe tank again, so I suspect the plug may (car side, not the tank side) be the problem. With the pump out of the tank I confirmed that the fuel lines were completely dry when O popped them off and that the pump was not running at key on or while the car was cranking. It seems odd that the old pump (220K miles) and the new pump both would not work.
Are there any other ideas? Is there any possibility there is 12v at the plug, enough to read on a DMM but not enough to run the pump motor?
Thanks!
