Everything posted by MNawd
2000 OBW Overheating at Highway Speed with A/C On...
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou guys are smart. I have about 10 things to look at and try and diagnose this thing. Thanks so much. Im glad to hear this is a rather simple thing to fix, not another HG style issue!!! Thank you! Ill respond once i figure out what it was!
Any advice? I have a 2000 OBW with 130K on it. Runs like a dream. I just noticed while driving in Hot weather (85 +) at highway speeds, with the AC on, my temp gauge starts to slowly climb up above 3/4. I have not hit red yet nor have i had any CEL's come on yet. I can have the AC on around town no problem, but at highway speeds (65 +) it starts to heat up. If i cycle the AC off, it starts to cool off slowly and then stays steady at 1/2. No smells, the AC is cold (when on), sounds like the fans are running, haven't really noticed anything weird. The only other piece of info that i have is that it seems to be dripping more than a normal amount of condensation under the front passenger side. I know it's supposed to drip condensation normally but it seems excessive. I had the dreaded HG problem fixed 1 year and 15K miles ago. Does anyone have any suggestions? Thermostat, Water Pump, Radiator, Fans??? What do you think? Thanks!
00 OBW Transmission Question
I have about 108K on my 00 OBW. I just took a 3K mile Road Trip from Minnesota out through Jackson Hole WY and up throught Yellowstone and back through MT. While in the mountains my tranni started to "slip" a little. If you were to come to a rolling stop and then give it some gas there is a lag and it kind of jumps into gear. Do i simply need a transmission flush? Or could it be that my tranni is going bad? I had my 90K mile maintenance done but i only had my transmission drained and re filled, not flushed. Do you think that would matter? Thanks for the input.
O2 Sensor and Catalytic converter
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for the input!
I have heard before that if one of your O2 Sensors goes out and you don't replace it, you run the risk of ruining your catalytic converter. Can anyone validate or disprove this statement? Just curious. Thanks.
Does anyone know the bolt pattern?
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting. Thanks. The wheels im looking at are stock off of a 2005 OBW. Do you know the offset of those stock rims? Thanks for the insight.
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsweet thanks!
Does anyone know off hand what the 2000 OBW Ltd bolt pattern is? I know it's 5 bolts but my wife has the car at work and i found a good deal on a set of 17" wheels. Oh, and does anyone know how to change the little tag under your name? Thanks, Lucas
Could It be my Fuel Pump?
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIll try that. Ill let you know what happens. Thanks guys. It's nice to know there are people who actually know what they are talking about as opposed to getting fed some line by some mechanic!
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBuilding oil pressure makes sense, but it's never done this before, even in -20 Degree weather! It cranks for about 4-5 seconds when it does this otherwise it will crank right over under normal conditions. Ill check the plugs to see if they are dirty. That could be the issue too. That would make sense, if the plug isn't igniting the mixture completely it could cause the CEL to pop on.
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas your CEL intermittent like mine or was it permanately on? How easy is it to fix?
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know, I don't have an Autozone around for 150 Miles is the problem. I had the codes pulled about a month ago and they said it came back clean with no codes read... Can the check engine light come on and not create a code? Can the computer in your car clear out the old codes after a certain amount of time? Thanks for the input though...
Hey, i have a 2000 OBW and my Check Engine light has been coming on more frequently as of late (last 6000K). It will turn on and be on for a couple hundred miles and then turn off. I haven't noticed anything wrong with the performance of my car. In fact it drives perfectly. The only little nuance that i have noticed in the last couple days is that it's starting a bit strange. When you turn the key the starter starts spinning but instead of the engine firing right away it just keeps spinning. Sometimes i let off the key and then turn it over again and it fires right up like nothing happened. Othertimes if you kind of stay on the starter for a second or two longer it will fire. My questions are... 1) could this be something to do with my fuel pump, injectors, or O2 Sensors? I know Check engine lights commonly come on for the sensors. 2) could the check engine light be related to this nuance? Im guessing possibly. Any advice would be greatly appreciated. Thanks.
So I decided it was time to sell the sub.. boy did i get some good news.. NOT!!!
MNawd replied to 98legacywv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's all pretty funny, Well not funny for you 98leg. I just brought my 00OBW in for a "free oil change" at the dealership i bought it at. I couldn't make it back by the time they closed so i didn't get a chance to talk with them yet but on the invoice it said under the "recomendations" area: Head gasket has bad leak, and front seal needs replacement. What a joke. I bought this car 7 months ago from this dealer. Ive put 11K miles on it and they are now telling me that i need a complete head gasket and front seal! I just had it in 6K ago for the 90K maintenance at a different garage and he said every thing looked great on the car, including the gaskets! I don't trust the dealerships. Unless they can take me under my car and show me exactly what they are trying to sell me on, im not buying it!
Crazy tailgate lock.............
MNawd replied to foamdad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a 00 OBW and i have that irregular problem as well...Weird. It seems to only happen once in a while and the gate is released by hitting my FOB lock, then unlock once. I have a rubber cargo tray in the back for my St. Bernard and i was just assuming that the rubber mat was kind of jamming the door somehow, Until, I spoke with my sister who has a 98 OBW and her's did the same thing! She has been having problems with hers for a couple of years now. Strange...
Check Engine Light in 00 OBW
MNawd replied to MNawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. Ill check out the error code and let you guys know what it was. It's off now and ive driven another 50 miles or so with no light. Weird. Thanks again!
Just this past Thursday my check engine light came on after driving my 00 OBW for about 180 miles. I got the car about a month ago and this is the longest trip its been on so you can understand my alarm. The car had 90,9XX miles on it when the light came on. The car drove fine, no noises, no hesitation, nothing i could tell that would be wrong. All the fluids look alright. The car sat for three nights while i was on vacation. I came back just this morning, the check engine light was still on. I put another 200 miles on it with it on and no issues that i could tell. The car sat at my house for probably three hours tonight until i went to pick up my wife from work. When i started the car, the check engine light did not come on!?!? What the heck is that all about? Anyone have any insight? Could it be some type of Major milestone in service that is required that it's just warning me about? Does this car's check engine light come on when the oil needs to be changed?(shouldn't be for another 1000 miles...) Is it something to do with the emission systems? Why would the light just go off by itself? Im just confused about it so if anyone has any insight on this topic, Id appreciate it!
Cool Pics
Ill see if i can make an appearance. Thanks for all the info. Ill be watching the site for the next up coming events!
Cool Pics
I just joined the MNsubaru board yesterday. Do you guys take kindly to newbies when you get together for events? I don't want to come over to one to be the new kid jacka** with the stock obw. But i would like to put this thing through some stuff. I get jelous of the jeep crews that get together (even the stock guys) and just go tooling around all the time. Let me know.
Cool Pics
That's Mint. I grew up with both those fellas. I played Baseball with Skrove in Frazee, Skrove and Ty both worked with me up here in Duluth at TrueRide. In fact Skrove lived with Osterman and i two years ago up here in Duluth. What's your name? We'll have to get together sometime so i can get my 00 OBW dirty dirty. ~Lucas Mistelske
Cool Pics
Just north of DL? That's mint. I grew up in Frazee. I live in Duluth now and just purchased my first Subaru. Yellow head trail huh? Where abouts is that? Id like to check it out next time i head home. Fun stuff this message board is!
