Hello, I'm the proud owner of a new '94 awd turbo wagon.  The thing is, I believe the AWD is not working at all.  I punch it on snow from a stop, the front wheels spin and spin forever.  It does not feel like my previous subies and I don't feel the rear end at all.  The front wheels will burn all the way thru 1st gear on dry pavement.
I've verified the proper hardware is installed underneath - tail end of tranny, drive shaft, diff, rear axles.
I've verified the FWD fuse is not installed.  I've verified installing the fuse will light the FWD indicator on the dash, and I pulled the fuse back out.
The transmission code procedure is giving codes 24 and 32:
Duty C solenoid
Speed sensor 1 (VSS1)
Additionally the Power light blinks 11 times when turning on the car.
CEL light is off, ABS light is off, and ABS functions properly.
I'm preparing to take the following action and would appreciate input from more experienced members of this community...
1) pull the main harness from the tranny to enter 'limp' mode forcing 50/50.  Drive and see if rear wheels provide power now.
-If so, look for TCU/harness issues and VSS1 issues.
-If still no power, install an oil gauge at the test port on the tranny tail, expecting 0psi indicating solenoid stuck Closed(bypass/fwd).  Replace solenoid, flush tranny, test again.
-If PSI is present, flush tranny.  If still no power, tear down tail inspecting for missing gaskets, torn basket, missing plates, check plate thickness, grooving thickness, oil feed line, etc.
Does this sound sensible?  Is there anythign else I should check before tearing the tranny down, laying in the snow?  Finally anyone in Denver area with a garage I can use? haha
Thanks in advance  Eric
