85 Gl
Everything posted by 85 Gl
  1. o ok thanks for clearing that up:)i also lifted the rear up and yea the other wheel spun the opposite way to wat i was spinnning the other way, thanks guys yet again:)
  2. k i checked the tag didnt say lsd on the tag the gear ratio was 3.9 so im guessing it is a lsd, i just dont think it is tho because ive never seen a lsd work like that my bro has a ford with lsd in the rear and it doesnt do that the diff in the suby is working more like a diff lock
  3. yep i no about the jack the entire rear off the ground and if the opposite wheel spins its lsd ill check the tag now
  4. my diff in me 85 gl 4wd d/r looks like it has a locked diff in the rear when i turn on the drive way i can hear it jumping on the innner wheel that i am turning i put one side on the jack and put it in 4wd and i could only turn the wheel a few inches then it would start driving the other side, so do these have locked diff
  5. What sort of carby is in a 85 Gl EA82 ive bought the manual for the car but it hasnt arrived so could someone answer this Q?
  6. yea i saw his post it doesnt have a o2 sensor in it, but now that i checked the exhaust it doesnt have a cat, did that come out in later cars or what?
  7. i live in NSW, Newcastle bout 2hrs from sydney
  8. ive searched but couldnt find much on this topic but how do i adjust the back ride height on a 85 Gl Ea82 in the manual it says theres bolts at the back to change the ride height but it doesnt say clearly where abouts these nuts are?
  9. ok its carbed so that must meen no Ecu
  10. anyone???
  11. Could somebody tell me how to replace them ive seen the guide to fix the slop for the EA81 is that the same for EA82
  12. the 85 Gl D/R have a ECU dont they because i was reading the acticle on how to get the codes so if it does where is the connecter??
  13. well i just put the back of the car on the ramps to righten the handbrake up hmm cant find the cable, looked up followed the cable it went to the front hmm weird cant be handbrake on the front wheel lifted up the front and yep it was weird never seen that before, bugger i cant do handbrakeys:( anyone got any ideas for rear braking ive heard of the hydraulic handbrake ive only just got the car and im gunna start rallying this in 2005 so i need a rear handbrake so anyone got any info on this rear handbrake............
  14. ok thanks for that
  15. first of hello to the board me and my dad race rally cars and have just got a 85 gl from a friend for free Dual range 4wd, 4wdlo its a Ea82 5 speed when you put it in gear you can move the gear stick all the way left and Right it does it in all gears is it just worn bushs or the gearbox?
